Recreate new 3D polyline based on a given slope
I’m currently working on a function that calculates a new 3D polyline based on a given slope and an existing polyline with chatGPT. However, I’ve encountered an issue where the last vertex of the created 3D polyline is showing incorrect X and Y coordinates. Im so close but i can not fix it. Can somebody help me?
(defun c:calculateNew3DPolylineWithSlope ( / js slope total_horizontal_length new_points pt_start pt_end inter_distance n start_z end_z ratio num_points)
  (princ "\nSelect a 3D polyline.")
  ;; Select the 3D polyline
  (setq js (ssget '((0 . "POLYLINE")))) ; Only polylines
  ;; Check if the selection is empty
  (if (not js)
      (princ "\nEmpty or invalid polyline selection!")
      (exit)  ;; Exit the command
  ;; Get the VLA object for the selected polyline
  (setq ename (vlax-ename->vla-object (ssname js 0)))
  ;; Calculate the total horizontal length of the polyline (X, Y plane)
  (setq total_horizontal_length 0.0)
  (setq num_points (fix (vlax-curve-getEndParam ename)))  ;; Total number of vertices
  ;; Check if the polyline has vertices
  (if (<= num_points 0)
      (princ "\nThe polyline has no valid vertices!")
      (exit)
  ;; Loop to calculate horizontal length
  (setq n 0)
  (while (< n num_points)
    (setq
      pt_start (vlax-curve-getPointAtParam ename (float n))   ;; Starting point at the n-th vertex
      pt_end (vlax-curve-getPointAtParam ename (float (1+ n)))  ;; Next point
      ;; Check if points are valid
      inter_distance 0.0
    ;; If both points are valid
    (if (and pt_start pt_end)
        ;; Calculate horizontal distance
        (setq inter_distance (distance (list (car pt_start) (cadr pt_start)) (list (car pt_end) (cadr pt_end)))  ;; Horizontal distance
              total_horizontal_length (+ total_horizontal_length inter_distance))  ;; Add horizontal distance
        ;; Print horizontal length to the current vertex
        (princ (strcat "\nHorizontal length to vertex " (itoa n) " is: " (rtos total_horizontal_length 2 2) " units."))
    (setq n (1+ n))
  ;; Get the desired slope from the user
  (setq slope (getreal "\nEnter the desired slope in percentage: "))
  (setq slope (/ slope 100.0))  ;; Convert to decimal
  ;; Calculate height based on the slope (slope * total horizontal length)
  (setq start_z (getreal "\nEnter the Z coordinate of the starting point: "))
  (setq end_z (+ start_z (* slope total_horizontal_length))) ;; Z coordinate of the last point
  ;; Create a list for new points
  (setq new_points '())
  ;; Interpolate heights between the first and last point
  (setq n 0)
  (setq horizontal_length_so_far 0.0)  ;; Horizontal length to the current vertex
    (setq pt_start (vlax-curve-getPointAtParam ename (float n))) ;; Get the n-th point
    ;; Check the validity of the point
    (if pt_start
        ;; Prevent division by zero
        (if (> num_points 0)
          (setq ratio (/ horizontal_length_so_far total_horizontal_length)) ;; Calculate ratio
          (setq ratio 0.0)
        ;; Interpolate Z coordinate considering horizontal length to vertex
        (setq interpolated_z (+ start_z (* ratio (- end_z start_z)))) ;; Interpolate Z
        ;; Add new point with new Z coordinate to the list
        (setq new_points (cons (list (car pt_start) (cadr pt_start) interpolated_z) new_points))
    ;; Add the horizontal length of the current vertex
    (if (< n (1- num_points))  ;; Ensure not to go out of bounds
      (setq next_pt_start (vlax-curve-getPointAtParam ename (float (1+ n)))  ;; Next point
            inter_distance (distance (list (car pt_start) (cadr pt_start)) (list (car next_pt_start) (cadr next_pt_start)))  ;; Horizontal distance
            horizontal_length_so_far (+ horizontal_length_so_far inter_distance)) ;; Accumulate horizontal length
    (setq n (1+ n))
Since you reported this solved, you should come back and provide the solution.
Not to mention, there may be better solutions.
Here is my solution.
(defun c:3Dppad ( / js pad total_horizontal_length l_pt pt_start pt_end inter_dist n start_z end_z ratio num_points)
  (princ "\nOdaberite 3D poliliniju.")
  ;; Selektovanje 3D polilinije
  (setq js (ssget '((0 . "POLYLINE")))) ; Samo polilinije
  ;; Proverava da li je izbor prazan
  (if (not js)
      (princ "\nNeprazan ili nevalidan izbor polilinije!")
      (exit)  ;; Izlazi iz komande
  ;; Dobijanje VLA objekta za odabranu poliliniju
  ;; Računanje ukupne horizontalne dužine polilinije (X, Y ravnina)
  (setq num_points (fix (vlax-curve-getEndParam ename)))  ;; Ukupan broj verteksa
  ;; Provera da li polilinija ima verteksa
      (princ "\nPolilinija nema validne vertekse!")
      (exit)
  ;; Petlja za računanje horizontalne dužine
  (setq n 0)
    (setq
      pt_start (vlax-curve-getPointAtParam ename (float n))   ;; Početna tačka na n-tom verteksu
      pt_end (vlax-curve-getPointAtParam ename (float (1+ n)))  ;; Sledeća tačka
      ;; Provera da li su tačke validne
      inter_dist 0.0
    ;; Ako su obe tačke validne
        ;; Izračunaj horizontalnu distancu
        (setq inter_dist (distance (list (car pt_start) (cadr pt_start)) (list (car pt_end) (cadr pt_end)))  ;; Horizontalna distanca
              total_horizontal_length (+ total_horizontal_length inter_dist))  ;; Dodaj horizontalnu distancu
        ;; Ispis horizontalne dužine do trenutnog verteksa
        (princ (strcat "\nHorizontalna dužina do verteksa " (itoa n) " je: " (rtos total_horizontal_length 2 2) " jedinica."))
    (setq n (1+ n))
  ;; Dobavljanje željenog nagiba od korisnika
  (setq pad (getreal "\nUnesite željeni pad (slope) u procentima: "))
  (setq pad (/ pad -100.0))  ;; Pretvaranje u decimalni oblik
  ;; Računanje visine na osnovu nagiba (pad * ukupna horizontalna dužina)
  (setq start_z (getreal "\nUnesite Z koordinatu početne tačke: "))
  (setq end_z (+ start_z (* pad total_horizontal_length))) ;; Z koordinata poslednje tačke
  ;; Kreiranje liste za nove tačke
  (setq l_pt '())
  ;; Interpolacija visina između prve i poslednje tačke
  (setq n 0)
  (setq horizontal_length_so_far 0.0)  ;; Horizontalna dužina do trenutnog verteksa
  (while (<= n num_points)
    (setq pt_start (vlax-curve-getPointAtParam ename (float n))) ;; Dohvata n-tu tačku
    ;; Provera validnosti tačke
    (if pt_start
        ;; Sprečavanje deljenja sa nulom
        (if (>= num_points 0)
          (setq ratio (/ horizontal_length_so_far total_horizontal_length)) ;; Izračunaj ratio
          (setq ratio 0.0)
        ;; Interpolacija Z koordinate uzimajući u obzir horizontalnu dužinu do verteksa
        (setq interpolated_z (+ start_z (* ratio (- end_z start_z)))) ;; Interpolacija Z
        ;; Dodaj novu tačku s novom Z koordinatom u listu
        (setq l_pt (cons (list (car pt_start) (cadr pt_start) interpolated_z) l_pt))
    ;; Dodaj horizontalnu dužinu trenutnog verteksa
    (if (<= n (1- num_points))  ;; Osigurati da ne idemo van granica
      (setq next_pt_start (vlax-curve-getPointAtParam ename (float (1+ n)))  ;; Sledeća tačka
            inter_dist (distance (list (car pt_start) (cadr pt_start)) (list (car next_pt_start) (cadr next_pt_start)))  ;; Horizontalna distanca
            horizontal_length_so_far (+ horizontal_length_so_far inter_dist)) ;; Akumuliraj horizontalnu dužinu
    (setq n (1+ n))
  ;; Kreiranje nove 3D polilinije sa zadatim nagibom
  (vla-put-Layer (vlax-invoke (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))) 'Add3DPoly (apply 'append (reverse l_pt))) (vla-get-Layer (ssname js 0)))
  (princ "\nNova 3D polilinija je uspešno kreirana sa zadatim nagibom.")
  (princ)  ;; Završavanje funkcije bez greške
  • Thanks 1
