hello all:
I would like your help to know if there is a lisp routine that helps check coordinates
when you have a non-zero origin
without having to move the drawings to the coordinate.
What I'm looking for is to assign an origin different from 0,0
and then list points to obtain the coordinates of the following figures
without having to draw dimensions or do addition or subtraction
or even without having to move the drawings since they are already arranged in viewports
I use the 2013 version.
any comments are welcome
thnaks
ORIGIN.dwg
Just do UCS OR, set a point as new 0,0 then I would do UCS S "MYUCS" then you can switch between your UCS and World, UCS W. Not sure how your doing the leaders, the X & Y value.
Edited by BIGAL
  • Thanks 1
