Hi,
Anyone know how I can get the centre lines to display? I have loaded the linetype but nothing is happening. I assume its a dimscale problem? What scale can I set my dims to?
Thanks
try to reduce your LTSCALE variable, but its a global variable so all linetypes are affected. if you need to edit only that line, select it then edit the line scale under its properties
Also be aware of PSLTSCALE variable if you are using viewports at all.
LineTypeScale - be aware that if you are viewing these lines in modelspace, they
may appear as a solid line, try looking at it through a viewport at a standard
scale.
