text in paper space appears very thick and solid
I have some drawings that the text appears very thick and solid in paper space.
Plots fine though.
i am still using a SHX font (architxt)
it shows fine in model space
only some drawings have this problem
i have checked txtfill and such commands
has anyone els ever had this issues?
again, it does not effect plotting, so its only annoying, not a real problem
thanks, Dale
Plots fine though.
thanks, Dale
This problem is common when using TTF fonts: some text in some file appear bold but when printed they look good (and I've seen this problem discussed in many forums with no clear explenation of the reasons why this happend).
This is the first time I hear that about SHX fonts.
BTW, on those fonts fillmode should not have effects because it's the lineweight (defined in the drawing or with the plot style) that should determine the width of the lines that forms the letters
Could you post your drawing or at least the portion with the text?
is it just text that appears thick?
Just a workaround, but turn off the LWT button at the bottom of the page.
I just uploaded a sample dwg with the text problem,
but there is no way to make it 250 kb, which I thought i saw was the limit, so i am not sure it is uploaded. It called sampletextdwg.zip
Its a zipped file
thanks, dale
I am using Acad 2002 still, i do not see LWT button, but will try to run it in command line
Yes, it is just the text that appears thick.
Nothing wrong in your drawing as far as I can see.
It's LWT on that give you the bold effect (as someone stated before).
Just turn it off > LWDISPLAY > OFF (or 0)
Thanks very much, something so simple...you would think i should have figured that out..
thanks again
Dale
thanks, It was the lwdisplay command
thanks again
Dale
Yea, fixed on my machine by turning of the LWT button at the bottom.
  • 10 years later...
I have had the same problem. The effected text has a Z value when listed even though it is in paper space. If I move the text to x,x,0'-0" it appears as it should.
I don't know how it gets moved in the Z direction in paper space but it does. It has started showing up on my plots too which won't be helped by the LWT setting!
I hope this helps.
Greg
  Greg001 said:
I hope this helps.
Probably a bit late, 10 years to the day late.
You are correct. However folks are always looking for answers. And, there's no such thing as stale question. Stale threads perhaps... besides, I'm new to this site/forum and admittedly didn't notice the date.
