AirBall Posted October 9, 2024 Posted October 9, 2024 Hi, Does anyone know how to get elevation from surface for polyline but only at vertices (TIN example and polyline with 8 vertices below ). So i want to mark TIN and polyline and then convert to 3D polyline with elevations in vertices (without intersections with edges of TIN). Example_surface.dwg Quote
hosneyalaa Posted October 9, 2024 Posted October 9, 2024 (edited) @AirBall Is it necessary through Lisp This can be done by forming cogo points from the surface of and then connecting the points through their numbers Edited October 9, 2024 by hosneyalaa Quote
BIGAL Posted October 9, 2024 Posted October 9, 2024 Like @hosneyalaa this is a inbuilt function in CIV3D. Do a google "get elevation of point on 3dface autocad lisp" there are answers out there found one from 2012. Quote
Tsuky Posted October 14, 2024 Posted October 14, 2024 @AirBall With your request :elevations in vertices Try this for convert your lwpolyline to 3Dpoly with 3Dfaces (defun pt_sum_store (pt? pt_lst / count p1 p2 vtx alpha btw_alpha) (setq alpha 0.0 vtx (car pt_lst) count 1 ) (while (< 1 (length pt_lst)) (setq p1 (car pt_lst) p2 (cadr pt_lst) pt_lst (cdr pt_lst) btw_alpha (q_ang pt? p1 p2) btw_alpha (if (< 180.0 btw_alpha) (- btw_alpha 360.0) btw_alpha ) alpha (+ alpha btw_alpha) ) (setq count (1+ count)) ) (setq btw_alpha (q_ang pt? p2 vtx) btw_alpha (if (< 180.0 btw_alpha) (- btw_alpha 360.0) btw_alpha ) ) (+ alpha btw_alpha) ) (defun q_ang (pt? p1 p2 / alpha beta) (setq beta (angle pt? p1) alpha (angle pt? p2) alpha (- alpha beta) ) (if (< alpha 0) (setq alpha (+ (* 2 pi) alpha)) ) (* (/ (float alpha) pi) 180.0) ) (defun pt_in_poly (pt? pt_lst / ) (if (equal 0.0 (pt_sum_store pt? pt_lst) 0.0001) nil T ) ) (vl-load-com) (defun c:lwpolyto3dpoly ( / js AcDoc Space ename obj pr lst_pt ss nb ent dxf_ent l_pt n X1 X2 X3 Y1 Y2 Y3 Z1 Z2 Z3 E1 E2 E3 E4 Z nw_lst-pt nw_obj) (princ "\nSelect polyline.") (while (null (setq js (ssget "_+.:E:S" (list (cons 0 "*POLYLINE") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) (cons -4 "<NOT") (cons -4 "&") (cons 70 112) (cons -4 "NOT>") ) ) ) ) ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (setq ename (ssname js 0) obj (vlax-ename->vla-object ename) pr -1 ) (repeat (fix (vlax-curve-getEndParam obj)) (setq pr (1+ pr) lst_pt (cons (vlax-curve-GetPointAtParam obj pr) lst_pt) ) ) (setq lst_pt (cons (vlax-curve-GetPointAtParam obj (1+ pr)) lst_pt)) (setq ss (ssget "_F" lst_pt '((0 . "3DFACE")))) (cond (ss (repeat (setq nb (sslength ss)) (setq ent (ssname ss (setq nb (1- nb))) dxf_ent (entget ent) l_pt (list (cdr (assoc 10 dxf_ent)) (cdr (assoc 11 dxf_ent)) (cdr (assoc 12 dxf_ent)) (cdr (assoc 13 dxf_ent)) ) ) (if (equal (car l_pt) (cadr l_pt)) (setq l_pt (list (list (cadr l_pt) (caddr l_pt) (cadddr l_pt)))) (setq l_pt (cons (list (car l_pt) (cadr l_pt) (caddr l_pt)) (list (list (cadr l_pt) (caddr l_pt) (cadddr l_pt))))) ) (mapcar '(lambda (y / n) (foreach e lst_pt (cond ((pt_in_poly e y) (setq n 0) (foreach item '(("X" . "'car") ("Y" . "'cadr") ("Z" . "'caddr")) (mapcar '(lambda (e) (set (read (strcat (car item) (itoa (setq n (1+ n))))) e)) (mapcar (eval (read (cdr item))) (car l_pt)) ) (setq n 0) ) (setq E1 (+ (* X1 (- Y2 Y3)) (* X2 (- Y3 Y1)) (* X3 (- Y1 Y2))) E2 (+ (* Y1 (- Z2 Z3)) (* Y2 (- Z3 Z1)) (* Y3 (- Z1 Z2))) E3 (+ (* Z1 (- X2 X3)) (* Z2 (- X3 X1)) (* Z3 (- X1 X2))) E4 (- (- (* E2 X1)) (* E3 Y1) (* E1 Z1)) Z (- (- (* (/ E2 E1) (car e))) (* (/ E3 E1) (cadr e)) (/ E4 E1)) nw_lst-pt (cons (trans (list (car e) (cadr e) Z) 1 0) nw_lst-pt) ) ) ) ) ) l_pt ) ) (setq nw_obj (vlax-invoke Space 'Add3dPoly (apply 'append nw_lst-pt ) ) ) (vla-put-Layer nw_obj (vla-get-Layer obj)) (vla-put-Color nw_obj (vla-get-Color obj)) (vla-put-Lineweight nw_obj (vla-get-Lineweight obj)) (vla-delete obj) ) ) (prin1) ) 4 Quote
AirBall Posted October 19, 2024 Author Posted October 19, 2024 @Tsuky Thank you very much, that is exactly what I needed. Quote
