3dwannab Posted October 8 Posted October 8 (edited) I've recently started a new job and tidying up the detail library. The majority of the drawing is a mess and was at all different elevations. So I started by using superflatten lisp found over on theswamp but it seems that when using the below code afterward it sends the objects to the X plane which shouldn't happen. See the attached drawing. The code that I'm using is: ;; Moves all visible objects to 0.0000 on the Z plane AKA Coplanar (defun C:NONZ () (vl-cmdf ".undo" "BEGIN") ; Added Crude Error Trap AKA UNDO (setvar "cmdecho" 1) ; turn off vl-cmdf echoing (vl-cmdf "zoom" "extents") (vl-cmdf "move" "all" "" "0,0,0" "0,0,1e99") (vl-cmdf "move" "all" "" "0,0,0" "0,0,-1e99") (vl-cmdf "zoom" "previous") (setvar "cmdecho" 1) (vl-cmdf ".undo" "END") ) ; Flatten Issue.dwg Edited October 8 by 3dwannab Quote
Steven P Posted October 8 Posted October 8 Seams to work better if you move the drawing to the origin instead of (120290, -60614) Quote
3dwannab Posted October 8 Author Posted October 8 18 minutes ago, Steven P said: Seams to work better if you move the drawing to the origin instead of (120290, -60614) Can you try the attached? It doesn't work for me. test.dwg 1 Quote
eldon Posted October 8 Posted October 8 It might be that there are many objects that are not parallel the the UCS. Your lisp just moves everything to a very great height vertically. If something is not parallel to the UCS, then it moves in a direction vertical to its own UCS but not to the current UCS. I don't know how to fix this, but someone clever probably knows how. I would just redraw the leaders, dimensions and hatches. Quote
Steven P Posted October 8 Posted October 8 Just trying that, it isn't working.... but you've told me that all ready. Looks like the hatches are hatching 3d lines - If I redraw the boundaries, hatch and then NONZ the new hatch does as expected. Just thinking as a fix, select all hatches - selection set - redraw the hatch, delete the original with the hatch points all at z=0, or recreate the boundaries and new hatch from there Quote
3dwannab Posted October 8 Author Posted October 8 (edited) It would be a huge undertaking on the existing detail library in the office to redraw everything but I guess that's what I'm going to have to do. I wasn't aware that objects can still have their own UCS. I don't understand how they can appear flat in the front view. FRONT VIEW OF THE ATTACHED (not very exciting to look at) Hatch example.dwg Edited October 8 by 3dwannab 1 Quote
Steven P Posted October 8 Posted October 8 (edited) That's the first thing I looked at too - a few 3d polylines are slightly off 0 z axis (like 0.000026, something like that) LISP would do the hatches no problem I think, do as a batch process and shouldn't be too painful - lunchtime walk while the machine does it stuff. Not sure the best way to go with that yet, perhaps entmake the hatch but apply (massoc.... ) lisp to the coordinates and entmod them with the result set with z axis set to 0 (mapcar '* '(1 1 0) coord ).. think that should work? Untested code idea: - do ssget and loop through each hatch entity as HatchEnt - (setq MyHatch (entget HatchEnt)) - (setq coords (Massoc 10 MyHatch)) - (Foreach n coords - (entmod (mapcar '* '(1 1 0) n) n MyHatch) - ) ; end foreach - ent update MyHatch - delete the original hatch I tested this quickly before dinner, scale was a bit off, so might need to adjust that - hatch scale was 6 in the drawing, I had to put it to about 0.25 to make it similar Edited October 8 by Steven P Quote
3dwannab Posted October 8 Author Posted October 8 I've noticed that the extrusion direction dxf code 210 is different on both hatches. 1 Quote
Steven P Posted October 8 Posted October 8 shouldn't have that... entmod them all to 0 extrusion? 1 Quote
3dwannab Posted October 8 Author Posted October 8 (edited) This is a testing version only but it seems to work. I wonder what CAD wizard made this mess of a detail library (vl-load-com) ;; ;; Fix the extrusuion values of hatches so they are 0,0,1 ;; ;; TESTING VERSION ;; ;; Thread here: https://www.cadtutor.net/forum/topic/92094-flatten-issue-with-drawing ;; ;; 3dwannab 2024.10.08 ;; ;; TO DO: ;; - Make this work for ENTITIES inside BLOCKS ;; (defun c:FXHatchExtrusion_To_0 (/ *error* acDoc cnt dxf210 ent entData newEntData newExtrude newExtrudeVal obj oldExtrude ss typ var_cmdecho) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) ) ;; Start the undo mark here (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) ;; Get any system variables here (setq var_cmdecho (getvar "cmdecho")) (setvar 'cmdecho 0) (if (setq ss (ssget "_:L" '((0 . "HATCH")))) (progn (repeat (setq cnt (sslength ss)) (setq cnt (1- cnt)) (setq ent (_dxf -1 (entget (ssname ss cnt)))) (setq entData (entget ent)) ; Get the entity's data list (setq obj (vlax-ename->vla-object ent)) (setq typ (cdr (assoc 0 (entget ent)))) (cond ;; Placeholder condition for other entities ; ((= typ "**") ; ) ;; end cond ;; Condition for HATCHES. ((= typ "HATCH") (setq newExtrudeVal 0.0) ; Set this to 0.0 (if (setq dxf210 (assoc 210 entData)) (progn (setq oldExtrude (cdr dxf210)) ;; Extract the current extrude components (setq newExtrude (list (nth 0 oldExtrude) newExtrudeVal (nth 2 oldExtrude))) ;; Create the new extrude with the modified Y component (setq newEntData (subst (cons 210 newExtrude) dxf210 entData)) ;; Replace the old extrude with the new extrude (entmod newEntData) ;; Apply the changes to the HATCH entity (entupd ent) ; Update the entity to reflect the change ) ) ) ;; end cond HATCH ) ) ) ;; progn ) ;; if ssget (if ss (progn (princ (strcat ">> " (itoa (sslength ss)) (if (> (sslength ss) 1) " objects extrude values are" " objects extrude value is") " fixed <<\n")) (sssetfirst nil ss) (command "_.regen") ) ) (vla-EndUndoMark acDoc) (*error* nil) (princ) ) ;; ----------------------------------------------------------------------- ;; ----------------------=={ Functions START }==-------------------------- ;;----------------------------------------------------------------------;; ;; _dxf ;; Finds the association pair, strips 1st element ;; args - dxfcode elist ;; Example - (_dxf -1 (entget (ssname (ssget) 0))) ;; Returns - <Entity name: xxxxxxxxxxx> (defun _dxf (code elist) (cdr (assoc code elist)) ) (c:FXHatchExtrusion_To_0) ;; Unlbock for testing Edited October 8 by 3dwannab 1 Quote
3dwannab Posted October 9 Author Posted October 9 Man, this drawing is a nightmare. I have this polyline with a 210 DXF of (210 0.0 0.0 -1.0) See attached. I've updated my code to include the DXF codes 220 and 230. When I run the program on this line it flips it seeing as the Z vector is -1.0. (vl-load-com) ;; ;; Fix the extrusuion values (dxf codes 210, 220 & 230) of all object so they are 0,0,1 ;; ;; TESTING VERSION - Use at your own risk ;; ;; Thread here: https://www.cadtutor.net/forum/topic/92094-flatten-issue-with-drawing ;; ;; 3dwannab 2024.10.08 ;; ;; TO DO: ;; - Make this work for ENTITIES inside BLOCKS ;; (defun c:FXExtrusion_To_0 (/ *error* acDoc cnt dxf210 ent entData newEntData newExtrude newExtrudeVal obj oldExtrude ss typ var_cmdecho) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) ) ;; Start the undo mark here (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) ;; Get any system variables here (setq var_cmdecho (getvar "cmdecho")) (setvar 'cmdecho 0) (if (setq ss (ssget "_:L" '((0 . "*")))) (progn (repeat (setq cnt (sslength ss)) (setq cnt (1- cnt)) (setq ent (_dxf -1 (entget (ssname ss cnt)))) (setq entData (entget ent)) ; Get the entity's data list (setq obj (vlax-ename->vla-object ent)) (setq typ (cdr (assoc 0 (entget ent)))) ; (setq newExtrudeVal 0.0) ; Set this to 0.0 (setq newExtrude (list 0 0 1.0)) ;; Create the new extrude with the modified Y component (if (setq dxf210 (assoc 210 entData)) (progn (princ "\ndxf210") (setq newEntData (subst (cons 210 newExtrude) dxf210 entData)) ;; Replace the old extrude with the new extrude (entmod newEntData) ;; Apply the changes to the entity (entupd ent) ; Update the entity to reflect the change ) ) (if (setq dxf220 (assoc 220 entData)) (progn (princ "\ndxf220") (setq newEntData (subst (cons 220 newExtrude) dxf220 entData)) ;; Replace the old extrude with the new extrude (entmod newEntData) ;; Apply the changes to the entity (entupd ent) ; Update the entity to reflect the change ) ) (if (setq dxf230 (assoc 230 entData)) (progn (princ "\ndxf230") (setq newEntData (subst (cons 230 newExtrude) dxf230 entData)) ;; Replace the old extrude with the new extrude (entmod newEntData) ;; Apply the changes to the entity (entupd ent) ; Update the entity to reflect the change ) ) ) ) ;; progn ) ;; if ssget (if ss (progn alloc (princ (strcat ">> " (itoa (sslength ss)) (if (> (sslength ss) 1) " objects extrude values are" " objects extrude value is") " fixed <<\n")) (sssetfirst nil ss) (command "_.regen") ) ) (vla-EndUndoMark acDoc) (*error* nil) (princ) ) ;; ----------------------------------------------------------------------- ;; ----------------------=={ Functions START }==-------------------------- ;;----------------------------------------------------------------------;; ;; _dxf ;; Finds the association pair, strips 1st element ;; args - dxfcode elist ;; Example - (_dxf -1 (entget (ssname (ssget) 0))) ;; Returns - <Entity name: xxxxxxxxxxx> (defun _dxf (code elist) (cdr (assoc code elist)) ) (c:FXExtrusion_To_0) ;; Unlbock for testing Extrusion Problem Code 210.dwg Quote
