Mountain_XD Posted October 8 Posted October 8 Please Help me. Thanks alot HOW TO DRAW LINE FROM BLOCK TO LINE BY LISP.dwg Quote
Emmanuel Delay Posted October 8 Posted October 8 (edited) Command DLBL (for Draw Line from Blocks to Line) (defun drawLine (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))) ;; DLBL for Draw Line from Blocks to Line (defun c:DLBL ( / ln blks i p1 p2) (setq ln (car (entsel "\nSelect line: " ))) (princ "\nSelect blocks: ") (setq blks (ssget (list (cons 0 "INSERT")))) (setq i 0) (repeat (sslength blks) ;; p1: insertpoint of the block (setq p1 (cdr (assoc 10 (entget (ssname blks i))))) ;; p2: closest point, perpendicular to the line. (setq p2 (vlax-curve-getClosestPointTo ln p1)) (drawLine p1 p2) (setq i (+ i 1)) ) ) Edited October 8 by Emmanuel Delay 2 Quote
