leos98 Posted April 4, 2009 Posted April 4, 2009 Hello, We have the following problem when setting xrefs, some architects leave stuff in the "0" layer and this should be a NO NO. I am looking for a LISP that would create a new layer named "0-From0" with the same properties of the 0"" layer and then move everything in the 0"" layer to new newly created "0-From0". I found this in helengorina.com but haven't been able to get it work. Unfortunately my experience with LISP is very little and haven't been able to debug it my self. (defun c:ZERO () (setq ssl0 (ssget “x” ‘((8 . “0")))) (COMMAND “-layer” “N” “from0" “”) (COMMAND “chprop” ssl0 “” “la” “from0" “”) ) Thanks! Leos98 Quote
Lee Mac Posted April 4, 2009 Posted April 4, 2009 Thought I might try it in VL, but can't seem to get this to work - not sure why, and its driving me up the wall... (defun c:0to0 (/ ss layers 0lay 0Nlay err) (if (setq ss (ssget "X" '((8 . "0")))) (progn (setq layers (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for lay layers (cond ((eq "0" (vla-get-name lay)) (setq 0lay lay)) ((eq "0-From0" (vla-get-name lay)) (setq 0Nlay lay)))) (if (not 0Nlay) (setq 0Nlay (vla-add layers "0-From0"))) (vla-put-color 0Nlay (vla-get-color 0lay)) (vla-put-linetype 0Nlay (vla-get-linetype 0lay)) (vla-put-lineweight 0Nlay (vla-get-lineweight 0lay)) (if (vl-catch-all-error-p (setq err (vl-catch-all-apply '(lambda (x) (vla-put-layer x "0-From0")) (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))))) (princ (strcat "\nError: " (vl-catch-all-error-message err))))) (princ "\n<!> No Objects Found on Layer \"0\" <!>")) (princ)) Quote
Lee Mac Posted April 4, 2009 Posted April 4, 2009 Well, this should get you through, but I'd be interested if anyone could offer some insight into the error in the above code ^^ (defun c:0to0 (/ ss layers 0lay 0Nlay) (if (setq ss (ssget "X" '((8 . "0")))) (progn (setq layers (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for lay layers (cond ((eq "0" (vla-get-name lay)) (setq 0lay lay)) ((eq "0-From0" (vla-get-name lay)) (setq 0Nlay lay)))) (if (not 0Nlay) (setq 0Nlay (vla-add layers "0-From0"))) (vla-put-color 0Nlay (vla-get-color 0lay)) (vla-put-linetype 0Nlay (vla-get-linetype 0lay)) (vla-put-lineweight 0Nlay (vla-get-lineweight 0lay)) (mapcar '(lambda (x) (vla-put-layer x "0-From0")) (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))))) (princ "\n<!> No Objects Found on Layer \"0\" <!>")) (princ)) Quote
architecture68-raff Posted April 4, 2009 Posted April 4, 2009 Hello,I found this in helengorina.com but haven't been able to get it work. Unfortunately my experience with LISP is very little and haven't been able to debug it my self. (defun c:ZERO () (setq ssl0 (ssget “x” ‘((8 . “0")))) (COMMAND “-layer” “N” “from0" “”) (COMMAND “chprop” ssl0 “” “la” “from0" “”) ) Leos98 When I copied and pasted your code into the Visual LISP editor, the quotation marks were not of the normal style. Try copying and pasting the following code and it should work correctly. It functions OK for me now. (defun c:ZERO () (setq ssl0 (ssget "X" '((8 . "0")))) (COMMAND "-layer" "N" "from0" "") (COMMAND "chprop" ssl0 "" "la" "from0" "") ) Quote
Lee Mac Posted April 4, 2009 Posted April 4, 2009 When I copied and pasted your code into the Visual LISP editor, the quotation marks were not of the normal style. Try copying and pasting the following code and it should work correctly. It functions OK for me now. (defun c:ZERO () (setq ssl0 (ssget "X" '((8 . "0")))) (COMMAND "-layer" "N" "from0" "") (COMMAND "chprop" ssl0 "" "la" "from0" "") ) It will function correctly, but the newly created layer "from0" will not be formatted the same as the original layer 0. Quote
architecture68-raff Posted April 4, 2009 Posted April 4, 2009 It will function correctly, but the newly created layer "from0" will not be formatted the same as the original layer 0. Oops. Forgot that requirement. Maybe this link will help you guys out with the visual lisp. http://www.autocode.com/lisp/layerswap.htm Quote
leos98 Posted April 4, 2009 Author Posted April 4, 2009 Thanks for your help guys, Lee Mac I'm getting this error when I tried your code: ; error: no function definition: VLAX-GET-ACAD-OBJECT Leos98 Well, this should get you through, but I'd be interested if anyone could offer some insight into the error in the above code ^^ (defun c:0to0 (/ ss layers 0lay 0Nlay) (if (setq ss (ssget "X" '((8 . "0")))) (progn (setq layers (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for lay layers (cond ((eq "0" (vla-get-name lay)) (setq 0lay lay)) ((eq "0-From0" (vla-get-name lay)) (setq 0Nlay lay)))) (if (not 0Nlay) (setq 0Nlay (vla-add layers "0-From0"))) (vla-put-color 0Nlay (vla-get-color 0lay)) (vla-put-linetype 0Nlay (vla-get-linetype 0lay)) (vla-put-lineweight 0Nlay (vla-get-lineweight 0lay)) (mapcar '(lambda (x) (vla-put-layer x "0-From0")) (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))))) (princ "\n<!> No Objects Found on Layer \"0\" <!>")) (princ)) Quote
Lee Mac Posted April 4, 2009 Posted April 4, 2009 Ahh sorry dude, forgot the good old (vl-load-com) - I have it in ACADDOC.lsp, so don't notice if its missed (defun c:0to0 (/ ss layers 0lay 0Nlay) (vl-load-com) (if (setq ss (ssget "X" '((8 . "0")))) (progn (setq layers (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for lay layers (cond ((eq "0" (vla-get-name lay)) (setq 0lay lay)) ((eq "0-From0" (vla-get-name lay)) (setq 0Nlay lay)))) (if (not 0Nlay) (setq 0Nlay (vla-add layers "0-From0"))) (vla-put-color 0Nlay (vla-get-color 0lay)) (vla-put-linetype 0Nlay (vla-get-linetype 0lay)) (vla-put-lineweight 0Nlay (vla-get-lineweight 0lay)) (mapcar '(lambda (x) (vla-put-layer x "0-From0")) (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))))) (princ "\n<!> No Objects Found on Layer \"0\" <!>")) (princ)) Quote
David Bethel Posted April 4, 2009 Posted April 4, 2009 You can try this: [b][color=BLACK]([/color][/b]defun c:zero [b][color=FUCHSIA]([/color][/b]/ nl td ss[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq nl [color=#2f4f4f]"0-From0"[/color] td [b][color=NAVY]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] [color=#2f4f4f]"0"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]tblsearch [color=#2f4f4f]"LAYER"[/color] nl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_New"[/color] nl[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_Color"[/color] [b][color=NAVY]([/color][/b]abs [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 62 td[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] nl[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_LType"[/color] [b][color=NAVY]([/color][/b]cdr [b][color=MAROON]([/color][/b]assoc 6 td[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] nl[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]""[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]8 . [color=#2f4f4f]"0"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.CHPROP"[/color] ss [color=#2f4f4f]""[/color] [color=#2f4f4f]"_LAyer"[/color] nl [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
leos98 Posted April 4, 2009 Author Posted April 4, 2009 Thanks for all of your great responses, You guys are amazing!! I wish I knew how to program LSIP like you guys, can you point to some sites or places where I can learn? Thanks again! Leos98 Quote
Lee Mac Posted April 4, 2009 Posted April 4, 2009 Thanks for all of your great responses, You guys are amazing!!I wish I knew how to program LSIP like you guys, can you point to some sites or places where I can learn? Thanks again! Leos98 There are tons of sites that offer help in LISP writing - demonstrating just how popular LISP is. heres a few of my suggestions: AfraLISP JefferySanders RonLeigh ABC's of AutoLISP and a few references: System Variables Entity References System Variable Alterations Quote
Lee Mac Posted April 5, 2009 Posted April 5, 2009 As requested (defun c:0to0 (/ ss layers 0lay 0Nlay) (if (setq ss (ssget "X" '((8 . "0")))) (progn (setq layers (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object)))) (vlax-for lay layers (cond ((eq "0" (vla-get-name lay)) (setq 0lay lay)) ((eq "0-From0" (vla-get-name lay)) (setq 0Nlay lay)))) (if (not 0Nlay) (setq 0Nlay (vla-add layers "0-From0"))) (vla-put-lock 0lay :vlax-false) (vla-put-color 0Nlay (vla-get-color 0lay)) (vla-put-linetype 0Nlay (vla-get-linetype 0lay)) (vla-put-lineweight 0Nlay (vla-get-lineweight 0lay)) (mapcar '(lambda (x) (vla-put-layer x "0-From0")) (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))) (princ (strcat "\n" (rtos (sslength ss) 2 0) " Objects Moved."))) (princ "\n<!> No Objects Found on Layer \"0\" <!>")) (princ)) If you have any queries about the code, or on anything else, just ask Cheers Lee Quote
leos98 Posted April 7, 2009 Author Posted April 7, 2009 Lee, Do I need (vl-load-com) anywhere in the code, or not anymore. Thanks! Quote
Lee Mac Posted April 7, 2009 Posted April 7, 2009 Sorry, yes you do (I always seem to forget it!)... [b][color=BLACK]([/color][/b]defun c:0to0 [b][color=FUCHSIA]([/color][/b]/ ss layers 0lay 0Nlay[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]vl-load-com[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] '[b][color=GREEN]([/color][/b][b][color=BLUE]([/color][/b]8 . [color=#2f4f4f]"0"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]progn [b][color=MAROON]([/color][/b]setq layers [b][color=GREEN]([/color][/b]vla-get-layers [b][color=BLUE]([/color][/b]vla-get-ActiveDocument [b][color=RED]([/color][/b]vlax-get-acad-object[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]vlax-for lay layers [b][color=GREEN]([/color][/b]cond [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eq [color=#2f4f4f]"0"[/color] [b][color=PURPLE]([/color][/b]vla-get-name lay[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setq 0lay lay[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eq [color=#2f4f4f]"0-From0"[/color] [b][color=PURPLE]([/color][/b]vla-get-name lay[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]setq 0Nlay lay[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]not 0Nlay[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq 0Nlay [b][color=BLUE]([/color][/b]vla-add layers [color=#2f4f4f]"0-From0"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]vla-put-lock 0lay :vlax-false[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]vla-put-color 0Nlay [b][color=GREEN]([/color][/b]vla-get-color 0lay[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]vla-put-linetype 0Nlay [b][color=GREEN]([/color][/b]vla-get-linetype 0lay[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]vla-put-lineweight 0Nlay [b][color=GREEN]([/color][/b]vla-get-lineweight 0lay[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]x[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]vla-put-layer x [color=#2f4f4f]"0-From0"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]mapcar 'vlax-ename->vla-object [b][color=BLUE]([/color][/b]mapcar 'cadr [b][color=RED]([/color][/b]ssnamex ss[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]princ [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\n"[/color] [b][color=BLUE]([/color][/b]rtos [b][color=RED]([/color][/b]sslength ss[b][color=RED])[/color][/b] 2 0[b][color=BLUE])[/color][/b] [color=#2f4f4f]" Objects Moved."[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\n<!> No Objects Found on Layer \"[/color]0\[color=#2f4f4f]" <!>"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] Quote
leos98 Posted April 7, 2009 Author Posted April 7, 2009 Hey, Is that with Notepad++ or Ultraedit? Quote
Lee Mac Posted April 7, 2009 Posted April 7, 2009 Hey,Is that with Notepad++ or Ultraedit? Nah, just ran it through an old LISP I got from David Bethel, puts all the necessary [ color=navy] bits in... Quote
