mdelo Posted Friday at 03:16 PM Share Posted Friday at 03:16 PM Hey all, I hope you all are well! Just running this idea, to see if any assistance can be given! Currently a bit new to LISP. Curious about the following functionality: LISP -> USER INPUT -> Place block w/ fields from user input? Looking to create similar functionality to the REVIT tag functions, where I can run the LISP, select a source object which to read certain fields. Thank you, and any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Steven P Posted Friday at 08:09 PM Share Posted Friday at 08:09 PM Yes that is possible, with LISP you can place a block using the entmake or entmakex method (for pure LISP) or the vla-insertblock (Visual LISP). These blocks can be defined with fields. You can use LISP to define the block definition including fields. Might need a little more information as to what exactly you want and perhaps a sample drawing s a demonstration of the fields to use Quote Link to comment Share on other sites More sharing options...
