mohammadreza Posted October 2 Posted October 2 hello guys i have a lisp that is count few blocks and put in a specific coordinates in a frame (rectangle). but if i move that frame, lisp doesnt work correctly (because that coordinates doent update) actually i searched too much and i found need to use ''entmakex'' function , but need some help. is this below code wrong? why? (defun c:bb () (setq block_obj (car (entsel "Select the block: ")) block_name (cadr (assoc 2 (entget block_obj))) ; Retrieve the block name text_ent (car (entsel "Select the text: ")) ) (entmakex (list '(0 . "ASSOC") (cons 2 (cons block_name text_ent)) ; Associate the block and text entities (cons 10 (cons block_name (cadr (assoc 10 (entget block_obj)))) ) (cons 11 (cons block_name (cadr (assoc 10 (entget block_obj)))) ) (cons 12 (cons block_name (cadr (assoc 10 (entget block_obj)))) ) ) ) (command "regen") (princ) ) Quote
marko_ribar Posted October 2 Posted October 2 What entity is ASSOC? This line : block_name (cadr (assoc 2 (entget block_obj))) ; Retrieve the block name Should be : block_name (cdr (assoc 2 (entget block_obj))) ; Retrieve the block name Quote
mohammadreza Posted October 2 Author Posted October 2 (edited) 15 minutes ago, marko_ribar said: What entity is ASSOC? This line : block_name (cadr (assoc 2 (entget block_obj))) ; Retrieve the block name Should be : block_name (cdr (assoc 2 (entget block_obj))) ; Retrieve the block name (my block name is rect ) ,i still get error: Command: BB Select the block: Select the text: error: bad DXF group: (2 "rect" . <Entity name: 15af94c8>) Cannot invoke (command) from *error* without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended. Edited October 2 by mohammadreza Quote
Steven P Posted October 2 Posted October 2 Is this what you are trying to do? Have a block with a field that updates as you move the block? The block can be a simple rectangle with a point and attribute - the point doesn't have to lie on the rectangle perimeter to allow the text / rectangle to be offset. To entmake or entmakex the field you create an mtext object with the text string being the field definition - which you might get from following this link: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-add-x-y-coordinates-to-block-attribute-in-AutoCAD.html#:~:text=Create a block with x,y coordinates as 1 Quote
Saxlle Posted October 2 Posted October 2 According to @Steven P post, i think this will help you (I wanted to post an example dwg, but there is a link with a description). Quote
