select blocks inside another block by lisp
Hi every one
I have some blocks named for example "AAA" inside another block, named for example "B" (nested blocks).
I have this lisp which is supposed to be able to select nested blocks, but it can not. It shows "No instances found".
would you please help me with that?
(defun c:selectNestedBlocks ()
  (setq ss (ssget "_X" '((2 . "AAA"))))  ; Selects all instances of the block "AAA" even if nested
  (if ss
    (princ (strcat "\n" (itoa (sslength ss)) " instances of 'AAA' selected."))
    (princ "\nNo instances found.")
See if this works for you...
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "AAA"))))
I misread which was the block and which was nested.  The above code will find blocks AAA, but not nested, you need to use B as the block searched for.
(setq ss (ssget "_X" '((0 . "INSERT")(2 . "B"))))
AFAIK, ssget doesn't do nested items.
See if this with colours can help...
(defun c:changeblksinsblks-nests ( / blockcomp-nest blocks ccc col doc flatten lay lac lll lss lst )
  (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com))
  (defun blockcomp-nest ( blk / ent enx lst )
    (if (setq ent (tblobjname "block" blk))
      (while (setq ent (entnext ent))
        (if (= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
          (setq lst (vl-list* (blockcomp-nest (cdr (assoc 2 enx))) ent lst))
          (setq lst (cons ent lst))
    (reverse lst)
  (defun blocks ( / blk lst )
    (while (setq blk (tblnext "block" (not blk)))
      (setq lst (cons (cdr (assoc 2 blk)) lst))
    (reverse lst)
  (defun flatten ( l )
    (if (atom l)
      (list l)
      (append (flatten (car l)) (if (cdr l) (flatten (cdr l))))
  (setq lay "BLK"     ;; Target layer
        col acbylayer ;; Target colour
        doc (vla-get-activedocument (vlax-get-acad-object))
        ccc 0
  (setq lst (blocks))
  (foreach itm lst
    (setq lll (cons (cons itm (blockcomp-nest itm)) lll))
  (setq lll (vl-sort lll (function (lambda ( a b ) (> (length (cdr a)) (length (cdr b)))))))
  (foreach itm lll
    (setq ccc (1+ ccc))
    (setq lac (strcat lay (itoa ccc)))
    (if (not (vl-position lac lss))
        (setq lss (cons lac lss))
        (if (not (tblsearch "layer" lac))
            (vl-cmdf "_.-LAYER" "_M" lac "_C" ccc)
            (while (< 0 (getvar (quote cmdactive)))
              (vl-cmdf "")
        (foreach e (flatten (cdr itm))
          (vla-put-color (vlax-ename->vla-object e) col)
          (vla-put-layer (vlax-ename->vla-object e) lac)
  (setvar (quote clayer) "0")
  (vla-regen doc acallviewports)
Regards, M.R.
