_civilpe Posted Monday at 10:39 PM Share Posted Monday at 10:39 PM I am writing a lisp routine to explode Civil 3D objects to then copy them to a CAD template. My lisp skips the "explode" command portion and heads straight into the copy objects to .dwt section without exploding the Civil 3D objects. How can I test my DWG to see if it contains Civil 3D objects before the lisp begins to copy objects to the .dwt file? Quote Link to comment Share on other sites More sharing options...
Steven P Posted Tuesday at 09:15 AM Share Posted Tuesday at 09:15 AM AECC objects? You could do an ssget with filter (ssget (list (cons 0 "*aecc*"))) to select them all (use '_X' for all the drawing) and then if the selection set is created you have what you searched for Quote Link to comment Share on other sites More sharing options...
BIGAL Posted Wednesday at 12:28 AM Share Posted Wednesday at 12:28 AM (edited) Inside CIV3D is the convert CIV3D objects to Autocad objects. "EXPORTTOAUTOCAD" will this help ? Please explain what objects ? Your request is to vague there is so many background functions in CIV3D. Just look at Toolspace. I have a couple of functions like make description key sets from Excel. Civ3d can export the key sets but not import. We had our CIV3D DWT set up, 250 layers, similar number blocks, linetypes and so on. Need blocks and layers to match description key sets for import field data. Use lee-mac steal to do this. Edited Wednesday at 12:30 AM by BIGAL Quote Link to comment Share on other sites More sharing options...
hosneyalaa Posted Wednesday at 06:00 AM Share Posted Wednesday at 06:00 AM Can you support it with an example drawing? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted Thursday at 12:00 AM Share Posted Thursday at 12:00 AM @_civilpe its your turn now. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted Thursday at 10:52 AM Share Posted Thursday at 10:52 AM Also, post your LISP efforts as well as a .dwg. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted Thursday at 12:26 PM Share Posted Thursday at 12:26 PM Why not just run a Script on all of the drawings to -EXPORTTOAUTOCAD? What would it matter if it did or did not contain AECC objects? From what I read there could be hidden Civil3D objects/information in the drawing, it could have information and not be detectable without some deeper searching. Quote Link to comment Share on other sites More sharing options...
