Find a text string inside a block that could change depending on job and insert a block accordingly
I am trying to write something that will look inside the ROFSHT block, if it exists, for a text string that contains "ZL24".  The ROFSHT block may not contain "ZL24" so it needs to check for that as well.  If it does have a text string that contains "ZL24" it won't always be the same exact string.  For example the full string in one drawing could be "PANELS:  24 Ga. ZL24 - GALVALUME" but in another the "GALVALUME" portion could be different.
I don't know if I am going about it the correct way but I have a portion of lisp that creates a list of all text entities in the ROFSHT block if it exists.
(if
  (setq ent (tblobjname "BLOCK" "ROFSHT"))
  (while (setq ent (entnext ent))
    (if (= (cdr (assoc 0 (entget ent))) "TEXT")
      (setq textList (cons (cdr (assoc 1 (entget ent))) textList))
This returns a list looking like this:
("PANELS: 24 Ga. ZL24 - GALVALUME" "ROOF SHEETING PLAN" "PANELS: 24 Ga. ZL24 - GALVALUME" "ROOF SHEETING PLAN" " OUT-TO-OUT OF STEEL" "100'-0\"" "5\"" "5\"" "25'-0\"" "25'-0\"" "25'-0\"" "25'-0\"" "4" "3" "2" "5" "1" "50'-0\" OUT-TO-OUT OF STEEL" "A" "D" "1" "25'-0\"" "25'-0\"")
Do I need to iterate through the list and use wcmatch with a pattern of "*ZL24*" and if the condition is T it will insert the block I tell it to?
Or
Do I need to add wcmatch to the code above?
Or
Is there a different way to achieve this?
At any rate I'm lost on how to accomplish this the rest of the way.
I have attached a sample drawing that has the ROFSHT block in it.
Thanks
RoofDwg2.dwg
After looking at the dwg I am confused why is the  ROFSHT even a block ? Why not a roof layout on its own and the label could be a 2 line attribute block.
Did you copy and paste from another dwg ? When pasting don't use the paste as block option.
The quickest answer is EXPLODE !!
For me I would look at using a label block when doing this type of thing this way it has a name, text style,  a color and a layer.
After you get that list, you can test to see if there is a string containing "ZL24 "
  (foreach l1 textList
    (cond
      ((wcmatch l1 "*ZL24*") (princ (strcat l1 " OK\n")))
On the other hand, assuming that the program doesn't need textList for something else, you could test the texts as you get them, something like:
(if
    (if (= (cdr (assoc 0 (setq el (entget ent)))) "TEXT")
	  (cond
	    ((wcmatch (setq txt1 (cdr (assoc 1 el)) "*ZL24*") (princ (strcat txt1 " OK\n")))
Or maybe a little bit simpler:
(defun c:pp()
 (if
    (setq el (entget ent) a0 (cdr (assoc 0 el)))
    (cond
      ((and (= a0 "TEXT") (wcmatch (setq txt1 (cdr (assoc 1 el))) "*ZL24*")) (princ txt1))
