llmb0611 Posted September 27 Posted September 27 Hi. I'm trying to find a lisp routine that would solve my problem. I have a lot of polylines, and each polyline should have one block placed on a midpoint (doesn't matter where, it just has to be midpoint). But when I select all polylines and blocks I don't have the same number. So now I should search for polylines that maybe have 2 or more blocks on one polyline, and polylines that don't have any blocks placed on them. Is that even possible? Thank you. If needed I can place a sample file. Quote
llmb0611 Posted September 28 Author Posted September 28 Here's a sample file. In the sample green lines are ok. They have a block placed on midpoint. The red lines are not ok. One has a block near the polyline, and one polyline doesn't have a block. sample.dwg Quote
llmb0611 Posted September 28 Author Posted September 28 here's a new sample file. I added one more polyline that contains 2 blocks. that's also not ok. sample.dwg Quote
Steven P Posted September 28 Posted September 28 Is the block insert point (generally point 0,0 in the block) on the polyline, or very close to it or does the placed on a polyline mean any part of the block overlaps the polyline? This might be a starting point (weekend, CAD is off so have to come back to this) Quote
BIGAL Posted September 28 Posted September 28 Using (SSGET "F" pts) this should find any object that touches or crosses a pline, the pts are the pline vertices. Obviously depend on the block. Quote
