Exporting a block to a file using WBLOCK
Hello Dear AutoCAD programmers!
Please tell me how to export a block from a drawing using the code (excel-vba) using the command WBLOCK -> Block (existing block)? !Data source - "Block"
The code below allows you to export only the selected, but I need to export an existing block by selecting it by name.
Dim myBlock As AcadBlockReference
Dim oEnt As AcadEntity
Dim sourceObj As Object
Dim Sset As AcadSelectionSet
StartF = "C:\"
Set App = CreateObject("Excel.Application")
With App.FileDialog(3)
  .AllowMultiSelect = False
  .Title = "Select File with Block"
  .Filters.Clear
  .Filters.Add "Drawing Files", "*.dwg;*.dwt", 1
  .InitialFileName = StartF
  .InitialView = 2
  If .Show = 0 Then
    MsgBox "Not selected."
  Else
    For lf = 1 To .SelectedItems.Count
      Set awCopy = acadApp.Documents.Open(.SelectedItems(lf))
      For Each oEnt In awCopy.ModelSpace
      If TypeOf oEnt Is AcadBlockReference Then
        Set myBlock = oEnt
        If UCase(myBlock.EffectiveName) = UCase(blockname1) Then
            Set sourceObj = myBlock
            Exit For
        End If
      End If
     Next oEnt
    If VarType(sourceObj) <> vbEmpty Then
     Set Sset = awCopy.SelectionSets.Add("WBLOCKSET")
     Sset.AddItems sourceObj
     awCopy.Wblock "C:\Acad_user\temp\WBlock_example.dwg", Sset
     Sset.DELETE
    End If
    Next
  End If
End With
Perhaps the following line needs to be changed somehow:
Edited by Oga87
