mohammadreza Posted September 20 Posted September 20 hello friends, is it possible to create toolbar and when i click on icon goes to new page of toolbar with new buttons and can to came back .!? Quote
BIGAL Posted September 21 Posted September 21 A tool bar can have sub toolbars called flyout need to look at help I have done it but don't do normally. https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-C3524378-3295-4708-9855-CF1353706A80 Quote
mohammadreza Posted September 21 Author Posted September 21 8 hours ago, BIGAL said: A tool bar can have sub toolbars called flyout need to look at help I have done it but don't do normally. https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-C3524378-3295-4708-9855-CF1353706A80 i watched a video about autocad R14 , in that video has a toolbar such as i mentioned in my question! afte click goes to new page ? CADR14.mp4 Quote
BIGAL Posted September 22 Posted September 22 (edited) Ok that is not a toolbar, you have to be old like me, its a screen menu may be wrong name. It was very useful can have sub menu's etc it was a nice option but disappeared, you could click on an option like walls and it would open a submenu with wall sizes and so on. Its very old trying to find an old mnu for you, it was called in a mnu by using $S option, $I is image. You had mnu sections that match the say $S=BL Begin AutoCAD Screen Menus ***SCREEN **S [AutoCAD]^C^C^P(ai_rootmenus) ^P [* * * *]$S=OSNAPB [ASE:]^C^C^P(ai_aseinit) ^P [BLOCKS]$S=X $S=BL [DIM:]^C^C$S=X $S=DIM0 _DIM [DISPLAY]$S=X $S=DS [DRAW]$S=X $S=DR [EDIT]$S=X $S=ED [INQUIRY]$S=X $S=INQ [LAYER...]^C^C_DDLMODES [MODELER]$S=X $S=SOLIDS [MVIEW]$S=MVIEW [PLOT...]^C^C_PLOT [RENDER]$S=X $S=RENDER [SETTINGS]$S=X $S=SET [SURFACES]$S=X $S=3D [UCS:]^C^C_UCS [UTILITY]$S=X $S=UT [SAVE:]^C^C_QSAVE This was a sub menu contained within you menu. mnu file. **SET_SC 2 [SCALES: ] [ 1:1 ]1 [ 1:2 ]2 [ 1:5 ]5 [ 1:10 ]10 [ 1:20 ]20 [ 1:25 ]25 [ 1:50 ]50 [ 1:100 ]100 [ 1:200 ]200 [ 1:250 ]250 [ 1:500 ]500 [ 1:1000]1000 Found the calling command. (menucmd "S=SET_SC") This was like 30 years ago so a bit hard to remember how to do it. Maybe something like this has around 130 lisps behind it. Edited September 22 by BIGAL 1 Quote
