lisp for auto print to pdf from model
  On 9/18/2024 at 8:52 AM, shokoufeh said:
Thanks
The reason why I didn't explain completely in the beginning, was that I didn't know how lisps work and how to program it, and I was not even sure about what I need 😕
Here, I mean a situation that for example I define 2 blocks. one for portrait plot and one for landscape plot. for example blocks names "PDF-Port" and "PDF-Land". So the program  doesn't need to ask the orientation from the user, and it can understand which sheets to plot in which orientation.
Expand
Sorry posted the wrong version where I was testing something else, here is the code I wanted to post in my previous post as it was explained there, auto detect if portrait or landscape, try this.
(vl-load-com)
(defun c:PDFA1 (/ lst lst_sort lst1 lst2 n Ysort dwg file hnd i len llpt lst mn mx ss tab urpt)
  (initget 1 "name1 name2")
  (setq plotstyle (getkword "\nChoose plot style [name1/name2]: "))
  (initget 1 "A1 A2 A3 A4")
  (setq papersize (getkword "\nChoose paper size [A1/A2/A3/A4]: "))
  (cond ((= papersize "A1")
	 (setq papersize "ISO full bleed A1 (841.00 x 594.00 MM)")
	((= papersize "A2")
	 (setq papersize "ISO full bleed A2 (594.00 x 420.00 MM)")
	((= papersize "A3")
	 (setq papersize "ISO full bleed A3 (420.00 x 297.00 MM)")
	((= papersize "A4")
	 (setq papersize "ISO full bleed A4 (297.00 x 210.00 MM)")
	);cond
  (setq lst nil)
    (if (setq ss (ssget "_X" '((0 . "INSERT") (2 . "PDFA1"))))
                (setq hnd (ssname ss (setq i (1- i)))
                      tab (cdr (assoc 410 (entget hnd)))
                      lst (cons (list hnd (cdr (assoc 10 (entget hnd))) tab) lst)
	  (setq lst_sort nil)
	  (setq n 0)
	  (while (< n (length lst))
	    (if (not (vl-remove-if-not '(lambda (y) (equal (cadr (cadr (nth n lst))) y 0.01)) Ysort))
	      (setq Ysort (cons (cadr (cadr (nth n lst))) Ysort))
	      );if
	    (setq n (1+ n))
	    );while
	  (setq Ysort (vl-sort Ysort '(lambda (x y) (> x y))))
	  (setq n 0)
	  (while (< n (length Ysort))
	    (setq lst1 (vl-remove-if-not '(lambda (x) (equal (nth n Ysort) (cadr (cadr x)) 0.01)) lst))
	    (setq lst2 (vl-sort lst1 '(lambda (x y) (< (car (cadr x)) (car (cadr y))))))
	    (setq lst_sort (append lst_sort lst2))
	    (setq n (1+ n))
	    );while
            (setq i 0)
            (foreach x lst_sort
                (setq file (strcat (getvar 'DWGPREFIX)
                                   (substr (setq dwg (getvar 'DWGNAME)) 1 (- (strlen dwg) 4))
                                   (itoa (setq i (1+ i)))
                                   ".pdf"
                (if (findfile file)
                    (vl-file-delete file)
                (vla-getboundingbox (vlax-ename->vla-object (car x)) 'mn 'mx)
                (setq llpt (vlax-safearray->list mn)
                      urpt (vlax-safearray->list mx)
                      len  (distance llpt (list (car urpt) (cadr llpt)))
	        (if (< (- (car llpt) (car urpt)) (- (cadr llpt) (cadr urpt)))
		  (setq draworient "Landscape")
		  (setq draworient "Portrait")
		  );if
                (command "-plot"
                         "yes"
                         (car x)
                         "DWG TO PDF.PC3"
			 papersize
                         ;"ISO full bleed A1 (841.00 x 594.00 MM)"
                         "Millimeters"
			 draworient
                         ;"Landscape"
                         "No"
                         "Window"
                         llpt
                         urpt
                         "Fit"
                         "Center"
                         "yes"
			 plotstyle
			 ;"acad.ctb"
                         ;"Standard-A1.ctb"
                         "yes"
                (if (/= (caddr x) "Model")
                    (command "No" "No" file "no" "Yes")
                    (command
                        file
                        "no"
                        "Yes"
And completely understandable, you asked for help, I just wanted to say a lot can be done but all details need to be known to start the right way from the beginning.
(vl-load-com)
	((= papersize "A2")
	((= papersize "A3")
	((= papersize "A4")
	);cond
  (setq lst nil)
	  (setq lst_sort nil)
	  (setq n 0)
	      );if
	    (setq n (1+ n))
	    );while
	  (setq n 0)
	    (setq n (1+ n))
	    );while
            (setq i 0)
            (foreach x lst_sort
                                   ".pdf"
                (if (findfile file)
		  );if
                (command "-plot"
                         "yes"
                         (car x)
                         "DWG TO PDF.PC3"
			 papersize
                         "Millimeters"
			 draworient
                         ;"Landscape"
                         "No"
                         "Window"
                         llpt
                         urpt
                         "Fit"
                         "Center"
                         "yes"
			 plotstyle
			 ;"acad.ctb"
                         ;"Standard-A1.ctb"
                         "yes"
                    (command
                        file
                        "no"
                        "Yes"
Expand
It worked great. Thanks a lot for your help 🙏
Edited by shokoufeh
