FInd a tablestyle by name and assign to a variable
Starting with this code that I found from Tharwat
(defun c:foo ()
 (setq StyleName "MyTableStyle") ; Prompt user for table style name
 (setq dic (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_TABLESTYLE"))))  ; Get the TableStyle dictionary
  (if (dictsearch dic StyleName)  ; Search for the specified Table Style in the dictionary
    (prompt "\nTable Style exists.")  ; If found, display this message
    (prompt "\nTable Style does not exist.")  ; If not found, display this message
How can I assign all the tables that meet that criteria to a selection set?
I was hoping it would be as easy as
(setq ss (ssget "_x" '((0 . "ACAD_TABLE") (302."MyTableStyle"))) )
but that does not work.
I do not know how to incorporate extended entity data
I would like to replace this
with if found make a selection set else exit.
How can I also find tables located inside of blocks and make part of the selection set?
(which I would also like to incorporate but only secondary)
QSelect does not find tables within blocks either..
I am not sure that you can get a table using a style name with ssget, but you can get all tables and look inside at the table name. two ways dxf or VL. Then make a new selection set or list of entities.
(setq sty (cdr (assoc 3 (entget (cdr (assoc 342 (entget (ssname ss X ))))))))
(setq obj (vlax-ename->vla-object (ssname ss x)))
(setq sty (vlax-get obj 'StyleName))
Inside blocks much harder need to use entnext and find the table inside the block, will leave that to some one else.
