Get list of certain text entities and mod them
I am needing to get a list of all the text entities within the DesCalc block that don't equal the text height of the table text objects and then after getting the list I need to mod them to have the same text height.
I have followed an answer that was given in a previous thread but it lists all entities of the block, I only want text entities that have text heights that don't equal the text heights of the entities in the table of the block.
Topic:  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-acces-entities-within-a-block/td-p/4572545
Reply:
(defun get-block-entities ( blk / ent lst )
    ;; Define the function, declare local variables
    (if ;; If the following returns a non-nil value
        ;; i.e. if the block exists in the drawing
        (setq ent (tblobjname "block" blk)) ;; get the BLOCK entity
        (while (setq ent (entnext ent))
            ;; Step through the entities in the block definition
            (setq lst (cons ent lst))
            ;; Construct a list of the block components
        ) ;; end WHILE
    ) ;; end IF
    (reverse lst) ;; Return the list
) ;; end DEFUN
My portion that I am trying to get to work but gives an error (; error: bad argument type: listp <Entity name: 283109094c0>)
;; --- Compile list of entity names of text objects with text heights that are different from the table text objects text height --- ;;
  (if
    (setq ent3 (tblobjname "BLOCK" "DesCalc"))
    (while (setq ent3 (entnext ent3))
      (if (and (eq (cdr (assoc 0 ent3)) "TEXT")
               (/= (cdr (assoc 40 ent3)) tbl_txtht))
        (setq lst (cons ent3 lst))
What do I need to change to be able to have a list of only entities with the criteria shown above?
After I get the list I believe I can just use a foreach function and loop through the list and mod the text heights accordingly like I do with the last portion of the lisp that is scaling the DesCalc block?
Full code
(defun c:WPD ()
  ;; --- User selects DesCalc.dxf from correct job folder to be inserted and places in drawing--- ;;
  (command "CLASSICINSERT" "\\")
  ;; --- Find EWTABL block and retrieve text height of the text object with contents of "MAXIMUM ASD REACTIONS" --- ;;
  (cond
    ((setq tbl1 (tblobjname "BLOCK" "EWTABL"))
      (setq ent1 (entget tbl1))
      (while (setq ent1 (entnext (cdar ent1)))
        (setq ent1 (entget ent1))
        (if (and (eq (cdr (assoc 0 ent1)) "TEXT")
                 (eq (cdr (assoc 1 ent1)) "MAXIMUM ASD REACTIONS"))
          (setq reaction_txtht (cdr (assoc 40 ent1)))
  ;; --- Find DesCalc block and retrieve text height of the text object with contents of "Zone" --- ;;
  (cond
    ((setq tbl2 (tblobjname "BLOCK" "DesCalc"))
      (setq ent2 (entget tbl2))
      (while (setq ent2 (entnext (cdar ent2)))
        (setq ent2 (entget ent2))
        (if (and (eq (cdr (assoc 0 ent2)) "TEXT")
                 (eq (cdr (assoc 1 ent2)) "Zone"))
          (setq tbl_txtht (cdr (assoc 40 ent2)))
  (if
  ;; --- Modify text entities from above to have same text height as table text objects --- ;;
  ;; ---     use foreach to loop through all entities in list to change text heights    --- ;;
  ;; --- Calculate scale factor --- ;;
  (setq scale_factor (/ reaction_txtht tbl_txtht))
  ;; --- Modify DesCalc scale in a single loop --- ;;
  (foreach axis (list 41 42 43)
    (setq descalc_blk (tblobjname "BLOCK" "DesCalc"))
    (setq descalc_ent (entget descalc_blk ))
    (entmod (subst (cons axis scale_factor) (assoc axis descalc_ent) descalc_ent)))
I have attached a drawing file with the necessary blocks for the lisp to run
AnDwg-4.dwg
So for your portion:
In your (assoc 0 ent3) and (assoc 40 ent3) lines  'ent3' is the entity name and not the entity description - there is no assoc to find in '<Entity name: 283109094c0>'.. so to fix that 'entget' your entity name to get the description and then the assocs will work.
If you are making a list of entities then I'd create a selection set instead of a list using ssadd
  (if
      (if (and (eq (cdr (assoc 0 (entget ent3))) "TEXT")
               (/= (cdr (assoc 40 (entgetent3))) tbl_txtht))
