tamilkt16@gmail.com Posted September 12, 2024 Posted September 12, 2024 Excel VBA to open autocad script file with respective path defined and saveas with specific name RUNNING_dxf_insert.SCR. Test2.dxf Test1.dxf Quote
BIGAL Posted September 12, 2024 Posted September 12, 2024 You need to paste the script in the code section use <> my pc thinks its a program script. If you look at this Excel example it has the VBA for linking to a DWG and making objects, you will need to look at how you send the command line for script. Sorry have to go now maybe later. draw object xl acad.xlsmdraw object xl bricscad.xlsm Quote
