Convert List Of Coordinates To Fence
I have a list of polyline vertex coordinates
((413540.0514,2885464.6320) (413537.4807,2885455.1222)  (413535.0813,2885449.2106))
I want to run this command transferring the list of vertex coordinates same as this example so the command accepts it as a fence
(vl-cmdf "_AeccDeleteSurfaceLine" "F" "413540.0514,2885464.6320" "413537.4807,2885455.1222" "413535.0813,2885449.2106" "" "" "")
Edited by SLW210
AddedCode Tags!!
I do it this way
(setq MySet (ssget "_W" PLL PUR))	; to use Lower left and upper right coords
(setq MySet (ssget "_F" (list PLL PLR PUR PUL PLL))) 	; to use fence
  On 9/11/2024 at 1:10 PM, kirby2 said:
I do it this way
Expand
I tried but "_AeccDeleteSurfaceLine" is different than SSGET , Thanks
Expand
Can't you plug the results of the SSGET into the command?
Perhaps like this? Sorry I don't have your vertical to test it.
setq MySet (ssget "_F" '((413540.0514,2885464.6320) (413537.4807,2885455.1222)  (413535.0813,2885449.2106))))
(vl-cmdf "_AeccDeleteSurfaceLine" Myset "" "" "")
(setq lst nil)
(if (and (setq ent (car (entsel))) (eq (cdr (assoc 0 (entget ent))) "LWPOLYLINE"))
		(setq pa (if (vlax-curve-IsClosed ent) (vlax-curve-getEndParam ent) (+ (vlax-curve-getEndParam ent) 1)))
		(while (setq pt (vlax-curve-getPointAtParam ent (setq pa (- pa 1))))
			(setq lst (cons pt lst))
(vl-cmdf "_AeccDeleteSurfaceLine" "F" lst)
The first part selects the polyline and extracts vertex coordinates to a list
I need to delete lines from the surface using the command "_AeccDeleteSurfaceLine" with parameter "F" fence
Test.dwgFetching info...
"The first part selects the polyline and extracts vertex coordinates to a list " ok a list would normally not have the "," seperating the X & Y. If you want to use X,Y then it needs to be a string.
(setq plent (entsel "\nPick rectang"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
((413540.0514 2885464.6320) (413537.4807 2885455.1222)  (413535.0813 2885449.2106))
or
("413540.0514,2885464.6320" "413537.4807,2885455.1222" "413535.0813,2885449.2106")
The other way is using something like this change pline to "_AeccDeleteSurfaceLine" need a couple more""
(defun AHpllst ( lst / x)
(command "_pline")
(while (= (getvar "cmdactive") 1 )
(repeat (setq x (length lst))
(command (nth (setq x (- x 1)) lst))
(command "")
 Sorry not tested.
Edited by BIGAL
  • Thanks 1
or
(command "_pline")
(command "")
 Sorry not tested.
Expand
(command "_pline")
(command "")
Perfect .. This command solved the issue. Thanks 🌹
Edited by SLW210
Added Code Tags!!
Please use Code Tags in the future. (<> in the editor toolbar)
  • Agree 1
Expand
Ok 🙏
