Nikon Posted September 10, 2024 Posted September 10, 2024 (edited) Is it possible to use lisp to shade selected outlines (several at once) with separates hatchings Solid? There are many polylines (rectangles) that need to be filled with separates hatchings... How can this be applied to multiple outlines: (vl-cmdf "_.-hatch" "_s" r "" "_p" "SOLID" "" "" "") Edited September 10, 2024 by Nikon Quote
rlx Posted September 10, 2024 Posted September 10, 2024 just use toggle 'Create separate hatches' 1 Quote
Nikon Posted September 10, 2024 Author Posted September 10, 2024 On 9/10/2024 at 4:54 PM, rlx said: just use toggle 'Create separate hatches' Expand I know this, but I have a lot of outlines in my drawing, and it takes a very long time to highlight each of them... Quote
rlx Posted September 10, 2024 Posted September 10, 2024 (defun c:t1 ( / al ss ) (setq al (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object)))) (if (setq ss (ssget "_X" (list '(0 . "LWPOLYLINE")))) (vlax-for o (setq s (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (setq h (vla-addhatch (vlax-get al 'block) acHatchPatternTypePredefined "SOLID" :vlax-true)) (vlax-invoke h 'AppendOuterLoop (list o))(vlax-invoke h 'Evaluate) ) ) (princ) ) (defun c:t2 ( / al ss) (setq al (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object)))) (princ "\nSelect objects to apply solid hatch to : ") (if (setq ss (ssget (list '(0 . "LWPOLYLINE")))) (vlax-for o (setq s (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (setq h (vla-addhatch (vlax-get al 'block) acHatchPatternTypePredefined "SOLID" :vlax-true)) (vlax-invoke h 'AppendOuterLoop (list o))(vlax-invoke h 'Evaluate) ) ) (princ) ) 3 Quote
Nikon Posted September 10, 2024 Author Posted September 10, 2024 (edited) On 9/10/2024 at 6:39 PM, rlx said: (defun c:t2 ( / al ss) (setq al (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object)))) (princ "\nSelect objects to apply solid hatch to : ") (if (setq ss (ssget (list '(0 . "LWPOLYLINE")))) (vlax-for o (setq s (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (setq h (vla-addhatch (vlax-get al 'block) acHatchPatternTypePredefined "SOLID" :vlax-true)) (vlax-invoke h 'AppendOuterLoop (list o))(vlax-invoke h 'Evaluate) ) ) (princ) ) Expand @rlx thank you very much!!! It will help me a lot. Edited September 11, 2024 by Nikon Quote
BIGAL Posted September 10, 2024 Posted September 10, 2024 Post a dwg. Should be able to use Hatchb.lsp to make a boundary and get the points of the boundary, if its more than 4 vertices or small sides are different lengths then it's not really a pline shape. 1 Quote
Nikon Posted September 11, 2024 Author Posted September 11, 2024 (edited) On 9/10/2024 at 11:14 PM, BIGAL said: Post a dwg. Should be able to use Hatchb.lsp to make a boundary and get the points of the boundary, if its more than 4 vertices or small sides are different lengths then it's not really a pline shape. Expand I am trying to convert (using the program SOLID_PLINE_HATCH_TO_PLINE) the created hatches into a polyline with global width=hatching width, but an entry is displayed on the command string: "The outline of the hatching is formed not only by a polyline". If the hatching is created by the autocad command, then the SOLID_PLINE_HATCH_TO_PLINE program works... PL_HATCH.dwgFetching info... Solid_pline_hatch_to_pline.fas.rarFetching info... Edited September 11, 2024 by Nikon Quote
BIGAL Posted September 12, 2024 Posted September 12, 2024 (edited) Sorry no help to existing code if your using a FAS file. I use Bricscad mostly now and fas is not supported. This is close to what you want, I have not looked at color of hatch but that could be added. Change layer name, the rectang around the hatch is erased, the hatch is still there on Hatch layer, again could be erased. You were lucky did the d1 d2 bit yesterday for another post. ; https://www.cadtutor.net/forum/topic/90914-fill-in-several-outlines-with-separates-hatchings/ ; Convert a rectang to a pline with width. : By Alan H Sep 2024 (defun C:Rect2pl ( / sspl co-ord x mp1 mp2 d1 d2) (command "-layer" "M" "HATCH2" "") (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq sspl (ssget (list (cons 0 "LWPOLYLINE")(cons 410 (getvar 'ctab))))) (setvar 'clayer "HATCH2") (repeat (setq x (sslength sspl)) (setq plent (ssname sspl (setq x (1- x)))) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent)))) (setq d1 (distance (car co-ord)(cadr co-ord))) (setq d2 (distance (cadr co-ord)(caddr co-ord))) (if (< d1 d2) (progn (setq mp1 (mapcar '* (mapcar '+ (nth 0 co-ord) (nth 1 co-ord)) '(0.5 0.5))) (setq mp2 (mapcar '* (mapcar '+ (nth 2 co-ord) (nth 3 co-ord)) '(0.5 0.5))) (command "pline" mp1 "W" d1 d1 mp2 "") ) (progn (setq mp1 (mapcar '* (mapcar '+ (nth 1 co-ord) (nth 2 co-ord)) '(0.5 0.5))) (setq mp2 (mapcar '* (mapcar '+ (nth 3 co-ord) (nth 0 co-ord)) '(0.5 0.5))) (command "pline" mp1 "W" d2 d2 mp2 "") ) ) (command "erase" plent "") ) (princ) ) Edited September 12, 2024 by BIGAL 1 Quote
Nikon Posted September 12, 2024 Author Posted September 12, 2024 (edited) Mr. @BIGAL This is an amazing program!!! I couldn't find this solution for a long time... Thanks a lot! A very good start to the day! Thanks for Rect2pl. Edited September 12, 2024 by Nikon Quote
BIGAL Posted September 12, 2024 Posted September 12, 2024 No worries as I had solved already the shortest side it was easy to do. 1 Quote
