Change linetype for all block inside AutoCAD drawing
Hello everyone.
I don't know how to do Lisp so I wanted to consult you. I use a lisp called ColorX that literally saved my life. Is there a version of this lisp that works with linetype logic?
There are many LISPs out there and many versions of them, are you able to post the ColorX lisp or a link to it so we know what it does?
Hi,
Can you post a dwg or an example file?
Why don't you have a go always a good time to learn.
At the heart of the code, is the change object property.
	     (vl-catch-all-apply 'vla-put-ExtensionLineColor (list Obj Color))
	     (vl-catch-all-apply 'vla-put-TextColor (list Obj Color))
	     (vl-catch-all-apply 'vla-put-DimensionLineColor (list Obj Color))
So if you look at the properties of an object using DUMPIT.lsp you should be able to work out correct Vla-put-property.
DumpIt.LSP
Just for the fun, i made a lisp wich change a linetype for all blocks.
(prompt (strcat "\nCopy and paste in command line: (command \"-LINETYPE\" \"?\" \"acadiso.lin\" \"\") to see all linetypes from \"acadiso.lin\" file.
Then from the column \"Name\" copy desire name of linetype and paste it in after execute \"CLTP\" command!
\nTo run a LISP type: CLTP"))
(defun c:CLTP (/ ltype ename blk_name ss len i blk ent rtn etype obj)
  (setq ltype (getstring "\nEnter the linetype name:"))
  (if (not (tblsearch "LTYPE" ltype)) ;; if linetype doesn't exist, it will be loaded
      (command "-LINETYPE" "L" ltype "acadiso.lin" "")
  (setq ename (car (entsel "\nSelect the desired block to change a linetype:")))
  (while (/= "INSERT" (cdr (assoc 0 (entget ename))))
    (prompt "\nSelected entitie is not a BLOCK! Try again...")
  (setq blk_name (cdr (assoc 2 (entget ename))))
  (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 blk_name))))
  (setq len (sslength ss))
  (setq i 0)
  (while (< i len)
    (setq blk (cdr (assoc 2 (entget (ssname ss i)))))
    (if (setq ent (tblobjname "BLOCK" blk))
      (while (/= ent nil)
	(setq ent (entnext ent))
	(if (/= ent nil)
	  (setq rtn (cons ent rtn))
    (setq i (1+ i))
  (setq i 0)
  (setq len (length rtn))
  (while (< i len)
    (setq etype (cdr (assoc 0 (entget (nth i rtn)))))
    (if (or (= etype "LINE") (= etype "CIRCLE") (= etype "ARC") (= etype "LWPOLYLINE"))
	(setq obj (vlax-ename->vla-object (nth i rtn)))
	(vlax-put-property obj 'Linetype ltype)
	(entupd (nth i rtn))
    (setq i (1+ i))
  (command "._regen")
Best regards.
Edited by Saxlle
