scubadoo Posted November 30, 2007 Author Share Posted November 30, 2007 as far as i know it is. How do i check? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 30, 2007 Share Posted November 30, 2007 as far as i know it is. How do i check? Double-Click it to open properties and select white or other and type in 255 in General>colors. Quote Link to comment Share on other sites More sharing options...
scubadoo Posted November 30, 2007 Author Share Posted November 30, 2007 I'll try that. One other question, once i've used text mask I don't seem able to edit the text and am only selecting the boundary of the text mask. Should I still be able to edit the text? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 30, 2007 Share Posted November 30, 2007 Double click it and Properties will open, at the top it will say "All(2)" in a drop down list, select MText and modify it in Properties. Quote Link to comment Share on other sites More sharing options...
CADGT Posted December 5, 2007 Share Posted December 5, 2007 Morning all, When i use the wipeout command rather than background mask in the Mtext window and plot my layout as a pdf, for some reason the wipeout prints as a black block. Is there a solution for this? Thanks Dave Use the WC command. Just type WC in the command line of all related drawings and Xrefs and that should fix it. Dont ask me what it stands for as i have no idea, but it works. I hope this helps. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 5, 2007 Share Posted December 5, 2007 Use the WC command. Just type WC in the command line of all related drawings and Xrefs and that should fix it. Dont ask me what it stands for as i have no idea, but it works. I hope this helps. I get "Unknown command "WC". Press F1 for help." Could this be a LISP? Quote Link to comment Share on other sites More sharing options...
joewaianae Posted December 5, 2007 Share Posted December 5, 2007 I get the same thing SLW, I think this is a Lisp that someone has put on there server and cadgt is unaware. Quote Link to comment Share on other sites More sharing options...
scubadoo Posted December 6, 2007 Author Share Posted December 6, 2007 Just got back on the machine and yes, my colour wipeout is white. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 6, 2007 Share Posted December 6, 2007 Just got back on the machine and yes, my colour wipeout is white. Use the color 255. Quote Link to comment Share on other sites More sharing options...
riga Posted December 6, 2007 Share Posted December 6, 2007 And in your plotstyles (if you are using CTB) set the screening for color 255 at about 10% Quote Link to comment Share on other sites More sharing options...
scubadoo Posted December 6, 2007 Author Share Posted December 6, 2007 Use the color 255. That's it! Thanks. So if i set up a layer called TEXT MASK, set the colout to 255, make it current, will the masks all come out correctly? Cheers guys. Quote Link to comment Share on other sites More sharing options...
CharlesHogge Posted July 25, 2012 Share Posted July 25, 2012 When plotting from Adobe I click on the "Advanced" button at the bottom of the printer dialog box. From there select "print as image," and select the default 300 dpi setting. This will allow the PDF to print the way it is viewed without taking any other information into consideration. I believe it has to do with the additional information that the PDF is holding since it retains layers, etc. Quote Link to comment Share on other sites More sharing options...
SanMiguel Posted November 27, 2014 Share Posted November 27, 2014 No luck on this wipeout turning black on PDF....anyone has other solution for this? thanks! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 1, 2014 Share Posted December 1, 2014 Are you using AutoCAD 2006 as your profile indicates? What PDF program are you using to plot PDFs? Have you tried using DWG Trueview FREE Autodesk viewer? http://www.autodesk.com/products/dwg/viewers-c?s_tnt=62493:2:0 Quote Link to comment Share on other sites More sharing options...
SanMiguel Posted December 1, 2014 Share Posted December 1, 2014 im using 2010, (havent updated my profile yet) and yes i tried using the DWF viewer and convert it to PDF, but our consultant is still saying that wipeout still turns black when they print it out. i ended up removing the wipeout & exploding the block to have a temp solution but im sooo frustrated with it. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 1, 2014 Share Posted December 1, 2014 Did you set the color to 255 and other suggestions above? I usually set text masked to "Use Background Color" or 255 and never had a problem plotting them using DWG to PDF.pc3 or Adobe, using default monochrome.ctb or acad.ctb. You may want to check what they are doing, seems this is on the consultant's end, if you are plotting them fine. Quote Link to comment Share on other sites More sharing options...
SanMiguel Posted December 1, 2014 Share Posted December 1, 2014 Yes i did try setting the color to 255 but to NO avail. Back & forth yet the problem still hunts me. Regarding the PDF.pc3, I've noticed that when i choose that plot setting, when I preview the PDF dwg, the lines seems to be somewhat light in color? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 2, 2014 Share Posted December 2, 2014 What .ctb or .stb are you using? Quote Link to comment Share on other sites More sharing options...
