harimaddddy Posted September 7 Share Posted September 7 (edited) Hi brothers/Sisters,  I create this code to create nominal diameter of a reinforcement, but while place the created circle it only center,  I want it to place with bottom of the circle.  Thanks in advance ;; Define a global variable for the last entered bar diameter (setq lastBarDiameter nil) (defun c:DG () ;; Initialize lastBarDiameter if it is nil (if (= nil lastBarDiameter) (setq lastBarDiameter 0.0)) ; Default value if no previous diameter is stored ;; Prompt for diameter input and allow pressing Enter to use last value (setq dia (getreal (strcat "\nEnter bar diameter (last entered: " (rtos lastBarDiameter 2 0) "): "))) ;; Check if the user pressed Enter (dia will be nil) (if (= dia nil) (setq dia lastBarDiameter) ; Use the last entered diameter if Enter is pressed ) ;; Validate and set the corresponding value (setq diameters '((3 . 0.375) (4 . 0.5) (5 . 0.625) (6 . 0.75) (7 . 0.875) (8 . 1.0) (9 . 1.270) (10 . 1.310))) ; List of diameters and values (setq n 0) ; Initialize n ;; Check for valid diameter and print corresponding message (foreach d diameters (if (= dia (car d)) (progn (setq n (cdr d)) (princ (strcat "\nYou entered a diameter of " (rtos (car d) 2 0) ", which corresponds to a value of " (rtos n 2 3) "."))))) ;; Only proceed if a valid diameter was entered (if (> n 0) (progn (setq pt (getpoint "\nSpecify the center point for the circle:")) ; Prompt for center point (setq radius (/ n 2)) ; Calculate the radius ;; Set the layer based on the bar diameter (cond ((= dia 3) (if (not (tblsearch "layer" "B3")) (command "LAYER" "M" "B3" "C" "10" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 4) (if (not (tblsearch "layer" "B4")) (command "LAYER" "M" "B4" "C" "14" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 5) (if (not (tblsearch "layer" "B5")) (command "LAYER" "M" "B5" "C" "30" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 6) (if (not (tblsearch "layer" "B6")) (command "LAYER" "M" "B6" "C" "40" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 7) (if (not (tblsearch "layer" "B7")) (command "LAYER" "M" "B7" "C" "50" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 8) (if (not (tblsearch "layer" "B8")) (command "LAYER" "M" "B8" "C" "70" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 9) (if (not (tblsearch "layer" "B9")) (command "LAYER" "M" "B9" "C" "99" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 10) (if (not (tblsearch "layer" "B10")) (command "LAYER" "M" "B10" "C" "110" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ) ;; Draw the circle at the specified center point (command "circle" pt radius) ;; Store the last entered bar diameter (setq lastBarDiameter dia) ; Store the last diameter value ;; Print the stored value (princ (strcat "\nLast entered bar diameter: " (rtos lastBarDiameter 2 0))) ; Use rtos for real display ) (princ "\nInvalid diameter. Please enter a value between 3 and 10.") ) ;; Set the current layer to 0-35 (or any default layer you want) (setvar "clayer" "0-35") ;; Clean exit (princ) )  Edited September 7 by SLW210 Added Code Tags!! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 7 Share Posted September 7 I moved your thread to the AutoLISP, Visual LISP & DCL Forum, please post in the most appropriate forum. Â Please use code tags for your code. (the <> in the editor tool bar) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 7 Share Posted September 7 (edited) This is my attempt at your task. Remembers last dia used. Adds circle matching bottom Quadrant point.  (defun c:DG ( / diameters ans radius pt ) (setq diameters (list "Choose diameter" "3/8" "1/2" "5/8" "3/4" "7/8" "1" "1 1/4" "1 3/8" )) ; List of diameters (if (not AH:Butts)(load "Multi radio buttons.lsp")) ; loads the program if not loaded already (if (= lastBarDiameter nil)(setq lastBarDiameter 1)) ; this is needed to set default button (setq ans (ah:butts lastBarDiameter "V" diameters)) (setq lastBarDiameter but) ;; Store the last entered bar diameter ;; Set the layer based on the bar diameter (cond ((= but 1) (setq radius 0.375)(if (not (tblsearch "layer" "B3")) (command "LAYER" "M" "B3" "C" "10" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 2) (setq radius 0.5)(if (not (tblsearch "layer" "B4")) (command "LAYER" "M" "B4" "C" "14" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 3) (setq radius 0.625)(if (not (tblsearch "layer" "B5")) (command "LAYER" "M" "B5" "C" "30" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 4) (setq radius 0.75)(if (not (tblsearch "layer" "B6")) (command "LAYER" "M" "B6" "C" "40" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 5) (setq radius 0.875)(if (not (tblsearch "layer" "B7")) (command "LAYER" "M" "B7" "C" "50" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 6) (setq radius 1.0)(if (not (tblsearch "layer" "B8")) (command "LAYER" "M" "B8" "C" "70" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 7) (setq radius 1.25)(if (not (tblsearch "layer" "B9")) (command "LAYER" "M" "B9" "C" "99" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= but 8) (setq radius 1.375)(if (not (tblsearch "layer" "B10")) (command "LAYER" "M" "B10" "C" "110" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ) (setq radius (/ radius 2.0)) ;; Draw the circle at the specified point (setq pt (getpoint "\nSpecify the bottom point for the circle:")) ; Prompt for bottom point (setq pt (mapcar '+ pt (list 0.0 radius 0.0))) (command "circle" "_non" pt radius) ;; Set the current layer to 0-35 (or any default layer you want) ;(setvar "clayer" "0-35") ;; Clean exit (princ) )  Make sure you save Multi radio buttons in a support path or add the full path to the (load "Multi... Multi radio buttons.lsp   Edited September 7 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
Saxlle Posted September 8 Share Posted September 8 Hi, I did a little update in your code and put a comments ("THIS LINE HAS BEEN ADDED", .......). I hope is that what you want. Â ;; Define a global variable for the last entered bar diameter (setq lastBarDiameter nil) (defun c:DG () ;; "THIS LINE HAS BEEN ADDED", you need to localized a variables (setq osm (getvar "osmode")) ;; "THIS LINE HAS BEEN ADDED", get the values of "object snap" (setvar "osmode" 0) ;; "THIS LINE HAS BEEN ADDED", set the value to be 0 or turned off (setq old_layer (getvar "clayer")) ;; "THIS LINE HAS BEEN ADDED", get a previous name of layer ;; Initialize lastBarDiameter if it is nil (if (= nil lastBarDiameter) (setq lastBarDiameter 0.0)) ; Default value if no previous diameter is stored ;; Prompt for diameter input and allow pressing Enter to use last value (setq dia (getreal (strcat "\nEnter bar diameter (last entered: " (rtos lastBarDiameter 2 0) "): "))) ;; Check if the user pressed Enter (dia will be nil) (if (= dia nil) (setq dia lastBarDiameter) ; Use the last entered diameter if Enter is pressed ) ;; Validate and set the corresponding value (setq diameters '((3 . 0.375) (4 . 0.5) (5 . 0.625) (6 . 0.75) (7 . 0.875) (8 . 1.0) (9 . 1.270) (10 . 1.310))) ; List of diameters and values (setq n 0) ; Initialize n ;; Check for valid diameter and print corresponding message (foreach d diameters (if (= dia (car d)) (progn (setq n (cdr d)) (princ (strcat "\nYou entered a diameter of " (rtos (car d) 2 0) ", which corresponds to a value of " (rtos n 2 3) "."))))) ;; Only proceed if a valid diameter was entered (if (> n 0) (progn (setq pt (getpoint "\nSpecify the center point for the circle:")) ; Prompt for center point (setq radius (/ n 2)) ; Calculate the radius ;; Set the layer based on the bar diameter (cond ((= dia 3) (if (not (tblsearch "layer" "B3")) (command "LAYER" "M" "B3" "C" "10" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 4) (if (not (tblsearch "layer" "B4")) (command "LAYER" "M" "B4" "C" "14" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 5) (if (not (tblsearch "layer" "B5")) (command "LAYER" "M" "B5" "C" "30" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 6) (if (not (tblsearch "layer" "B6")) (command "LAYER" "M" "B6" "C" "40" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 7) (if (not (tblsearch "layer" "B7")) (command "LAYER" "M" "B7" "C" "50" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 8) (if (not (tblsearch "layer" "B8")) (command "LAYER" "M" "B8" "C" "70" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 9) (if (not (tblsearch "layer" "B9")) (command "LAYER" "M" "B9" "C" "99" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 10) (if (not (tblsearch "layer" "B10")) (command "LAYER" "M" "B10" "C" "110" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ) ;; Draw the circle at the specified center point (command "circle" pt radius) (setq ang_270 4.71) ;; "THIS LINE HAS BEEN ADDED", define a default angle of 270 degrees, whic are in radians 4.71 (setq npt (polar pt ang_270 radius)) ;; "THIS LINE HAS BEEN ADDED", get a new point (npt) from the center point of the circle to the bottom of the circle (command "._move" (entlast) "" npt pt) ;; "THIS LINE HAS BEEN ADDED", displacement a circle from a bottom to the center of the circle (setvar "osmode" osm) ;; "THIS LINE HAS BEEN ADDED", restore the "object snap" ;; Store the last entered bar diameter (setq lastBarDiameter dia) ; Store the last diameter value ;; Print the stored value (princ (strcat "\nLast entered bar diameter: " (rtos lastBarDiameter 2 0))) ; Use rtos for real display ) (princ "\nInvalid diameter. Please enter a value between 3 and 10.") ) ;; Set the current layer to 0-35 (or any default layer you want) ;; (setvar "clayer" "0-35") (setvar "clayer" old_layer) ;; "THIS LINE HAS BEEN ADDED", restore the old layer after creating a circle ;; Clean exit (princ) ) Â Quote Link to comment Share on other sites More sharing options...
harimaddddy Posted September 8 Author Share Posted September 8 6 hours ago, Saxlle said: Hi, I did a little update in your code and put a comments ("THIS LINE HAS BEEN ADDED", .......). I hope is that what you want. Â ;; Define a global variable for the last entered bar diameter (setq lastBarDiameter nil) (defun c:DG () ;; "THIS LINE HAS BEEN ADDED", you need to localized a variables (setq osm (getvar "osmode")) ;; "THIS LINE HAS BEEN ADDED", get the values of "object snap" (setvar "osmode" 0) ;; "THIS LINE HAS BEEN ADDED", set the value to be 0 or turned off (setq old_layer (getvar "clayer")) ;; "THIS LINE HAS BEEN ADDED", get a previous name of layer ;; Initialize lastBarDiameter if it is nil (if (= nil lastBarDiameter) (setq lastBarDiameter 0.0)) ; Default value if no previous diameter is stored ;; Prompt for diameter input and allow pressing Enter to use last value (setq dia (getreal (strcat "\nEnter bar diameter (last entered: " (rtos lastBarDiameter 2 0) "): "))) ;; Check if the user pressed Enter (dia will be nil) (if (= dia nil) (setq dia lastBarDiameter) ; Use the last entered diameter if Enter is pressed ) ;; Validate and set the corresponding value (setq diameters '((3 . 0.375) (4 . 0.5) (5 . 0.625) (6 . 0.75) (7 . 0.875) (8 . 1.0) (9 . 1.270) (10 . 1.310))) ; List of diameters and values (setq n 0) ; Initialize n ;; Check for valid diameter and print corresponding message (foreach d diameters (if (= dia (car d)) (progn (setq n (cdr d)) (princ (strcat "\nYou entered a diameter of " (rtos (car d) 2 0) ", which corresponds to a value of " (rtos n 2 3) "."))))) ;; Only proceed if a valid diameter was entered (if (> n 0) (progn (setq pt (getpoint "\nSpecify the center point for the circle:")) ; Prompt for center point (setq radius (/ n 2)) ; Calculate the radius ;; Set the layer based on the bar diameter (cond ((= dia 3) (if (not (tblsearch "layer" "B3")) (command "LAYER" "M" "B3" "C" "10" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 4) (if (not (tblsearch "layer" "B4")) (command "LAYER" "M" "B4" "C" "14" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 5) (if (not (tblsearch "layer" "B5")) (command "LAYER" "M" "B5" "C" "30" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 6) (if (not (tblsearch "layer" "B6")) (command "LAYER" "M" "B6" "C" "40" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 7) (if (not (tblsearch "layer" "B7")) (command "LAYER" "M" "B7" "C" "50" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 8) (if (not (tblsearch "layer" "B8")) (command "LAYER" "M" "B8" "C" "70" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 9) (if (not (tblsearch "layer" "B9")) (command "LAYER" "M" "B9" "C" "99" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ((= dia 10) (if (not (tblsearch "layer" "B10")) (command "LAYER" "M" "B10" "C" "110" "" "L" "CONTINUOUS" "" "p" "n" "" ""))) ) ;; Draw the circle at the specified center point (command "circle" pt radius) (setq ang_270 4.71) ;; "THIS LINE HAS BEEN ADDED", define a default angle of 270 degrees, whic are in radians 4.71 (setq npt (polar pt ang_270 radius)) ;; "THIS LINE HAS BEEN ADDED", get a new point (npt) from the center point of the circle to the bottom of the circle (command "._move" (entlast) "" npt pt) ;; "THIS LINE HAS BEEN ADDED", displacement a circle from a bottom to the center of the circle (setvar "osmode" osm) ;; "THIS LINE HAS BEEN ADDED", restore the "object snap" ;; Store the last entered bar diameter (setq lastBarDiameter dia) ; Store the last diameter value ;; Print the stored value (princ (strcat "\nLast entered bar diameter: " (rtos lastBarDiameter 2 0))) ; Use rtos for real display ) (princ "\nInvalid diameter. Please enter a value between 3 and 10.") ) ;; Set the current layer to 0-35 (or any default layer you want) ;; (setvar "clayer" "0-35") (setvar "clayer" old_layer) ;; "THIS LINE HAS BEEN ADDED", restore the old layer after creating a circle ;; Clean exit (princ) ) Â This code works exactly what i needed sir, thanks... if i use this command a little zoom out then circle would place with center, but it can manageable when i zoom in near to the objects Quote Link to comment Share on other sites More sharing options...
Saxlle Posted September 8 Share Posted September 8 Your welcome  If i understand correctly, you have a problem with "object snap", doesn't apear a "quadrant" when you specifying center point of circle to be on "LINE, POLYLINE, ..." entitie. So, you need just to change a position of this line of code: (setvar "osmode" 0), to be somewhere after this line of code: (setq pt (getpoint "\nSpecify the center point for the circle:")) and before this line of code: (command "circle" pt radius) inside of "if" statement.  Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 9 Share Posted September 9 @harimaddddy did you try my code ? Does what you want. Yes must download Multi getvals.lsp as well. Quote Link to comment Share on other sites More sharing options...
harimaddddy Posted Saturday at 03:30 AM Author Share Posted Saturday at 03:30 AM @BIGALÂ Yeah i tried it, the menu bar idea is working fine, but for work follow i prefer use to keyboard only, thanks a lot i learnt a new thing. Quote Link to comment Share on other sites More sharing options...
