Costinbos77 Posted September 7 Share Posted September 7 Hi gents . Working around with some big lists of coordinates , I just came across the following : ; p i [x y z] (repeat n ... (setq l (cons p1 (cons p2 (cons p3 l))) ) ... ) And I said why in this way and not as below : ; p i [x y z] (repeat n ... (setq l (append (list p1 p2 p3) l) ) ... ) The result is the same , but the APPEND function takes far more time . (defun c:Test (/ c i l p te ts x y z) (princ "\n Test : V : 7 . 09 . 2024 ;") (setq c (if (= (getString "\n Test TYPE : Any = APPEND ; < Enter = CONS > : ") "") T nil) ts (getVar "cDate") x 35363738.123456789 y 53545556.123456789 z 2567.123456789 i 0 l nil) (repeat 5000 (setq x (+ x 1) y (+ y 1) z (+ z 1) p (list x y z) i (1+ i) ) (if c (setq l (cons p (cons p (cons p l))) ) (setq l (append (list p p p) l)) ) ; if ) ; r (setq te (getVar "cDate") ti (RtoS (* (- te ts) 10e6) 2 16) ) (princ (strcat "\n " (if c "CONS" "APPEND") " : i = " (itoA i) " ; Time = " ti " ;")) (princ) ) ; c:Test ; CONS : i = 5000 ; Time = 0.000000000000000 ; ; APPEND : i = 5000 ; Time = 40.00961780548095 ; Do you have the same big difference , or my computer is broken ? Regards , Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 7 Share Posted September 7 Since AutoLISP lists are stored as singly-linked lists in memory (whereby each element is a pair consisting of a value (car) and a pointer to the next pair (cdr), with the last pair containing a null pointer), using cons to push an item onto a list is a very efficient operation, as a new cons pair can simply point to the previous head of the list. Whereas, to append an element to the end of the list, the interpreter must traverse the entire linked list and point the last element to the newly appended element. As such, the performance of cons will not be impacted by the list length, whereas the performance of append will worsen by a factor of the list length. 2 Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted September 7 Author Share Posted September 7 (edited) Thank you very much for your detailed explanation . Now I, t is very clear . I was thinking CONS needs to push / move all the existing elements back down to create space for the new one , in which case is time-consuming. Regards , Edited September 7 by Costinbos77 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 7 Share Posted September 7 (edited) No - unlike an array (which is stored in contiguous memory), a linked list merely needs to update the pointers between successive elements. Edited September 7 by Lee Mac Quote Link to comment Share on other sites More sharing options...
