I've got a block that's used for titleblock information with attributes including drawing title, date, drawn by, checked by, etc. Is there a macro or a lisp routine that can be used to automatically change one attribute in a drawing. I need to change the "Approved By" attribute with the same initials in about 100 drawings, and I'm trying to find the quickest way to do this without actually having to type the initials in every drawing. I'm familiar with writing lisp routines, but not at all with visual basic and macros.
I'm running autocad 2004
Thanks in advance for any help.
In LISP, could be done like this:
(defun c:upd (/ ss att aLst)
 (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 "[b][color=Red]BLOCKNAME[/color][/b]")
   (cons 66 1) (if (getvar "CTAB")(cons 410 (getvar "CTAB"))
      (cons 67 (- 1 (getvar "TILEMODE")))))))
     (foreach x (mapcar 'cadr (ssnamex ss))
   (setq att (entnext x))
   (while (not (eq "SEQEND" (cdadr (setq aLst (entget att)))))
     (if (= "[color=Red][b]APPROVED_BY[/b][/color]" (cdr (assoc 2 aLst)))
       (entmod (subst (cons 1 "[b][color=Red]ABC[/color][/b]") (assoc 1 aLst) aLst)))
     (setq att (entnext att)))))
   (princ "\n<!> No Block Found <!>"))
 (command "_regenall")
 (princ))
Change the highlighted parts to suit.
I assume you mean "approved_by" instead of "approved by" as tags can't contain spaces. :thumbsup:
Thanks for the reply, this routine works well and is a great starting point.
If I wanted to edit several attributes using this command, what part of the routine would change?
For example, to edit "checked_by" and "approved_by" fields.
Or would I have to create a second routine and use two commands to execute it in a dwg?
Just change the IF to a COND like this:
 (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 "[color=Red][b]BLOCKNAME[/b][/color]")
     (cond ((= "[b][color=Red]APPROVED_BY[/color][/b]" (cdr (assoc 2 aLst)))
        (entmod (subst (cons 1 "[color=Red][b]ABC[/b][/color]") (assoc 1 aLst) aLst)))
       ((= "[b][color=Red]CHECKED_BY[/color][/b]" (cdr (assoc 2 aLst)))
        (entmod (subst (cons 1 "[color=Red][b]DEF[/b][/color]") (assoc 1 aLst) aLst))))
 (princ))
A couple of extra helps, you mention 100 dwgs you can create a script to open the dwgs and run automaticaly. You will be suprised how quick this happens.
open dwg1 (load "upd") upd close Y
open dwg2 (load "upd") upd close Y
if you put the upd.lsp in your startups then
open dwg1 upd close Y
Also if you need to vary the names or details to be changed maybe get it to read a data file this way you dont alter the lisp code all the time.
approved_by FRED
checked_by george
Revision 1
txt file
FRED
George
1
just add the read file before the if in lee's code
approved_by FRED
checked_by george
Revision 1
txt file
FRED
George
1
Nice one BiGAl, some great advice. :thumbsup:
