MR MAN Posted March 31, 2009 Posted March 31, 2009 How Change Line Length Depend On Attribute Value Change? By Any Way Lisp Or Vba Quote
CmdrDuh Posted March 31, 2009 Posted March 31, 2009 lots of ways to do this, some more complicated than others. You need a reactor either way I think. Thinking out loud, from VBA, using end command, watch for ddatte or eatte, then check block value, grab att, find line based on handle or some other method, adjust length Quote
uddfl Posted March 31, 2009 Posted March 31, 2009 Just throwing this out there: could there be a way to set up a dynamic block to do this? In any case, I'm in for the reactor. Quote
Lee Mac Posted March 31, 2009 Posted March 31, 2009 I tried experimenting with vlr-object-reactor, using vlr-subobjmodified - but my knowledge, as far as reactors go, is not very good. Quote
BIGAL Posted April 1, 2009 Posted April 1, 2009 Thinking outside the square back a few years ago was the "Shaft" demo (supportfiles) for the excel to acad link you could change the excel value and the drawing changed this may help with an answer. Quote
