RiccardoSusini Posted August 28 Posted August 28 Good morning, I have created a block with a rectangular shape having 5 lines that could be stretched and rotate by selecting the end point of the line in the model space. When I move this end point, the anchor length and angle changes while the position of the end point of the line (which is an attribute having as field the x,y coordinate of the end point of the line) is not syncronizing (I use BATTMAN,ATTSYNC), basically displaying always the same value. Do you think there is an error in correlating the position of the end point of a line inside the block editor that is not allowing then to syncronize the attribute in the model space? Quote
BIGAL Posted August 29 Posted August 29 It may be that when inserting a block with a field it has the ID only of the original object, you may need to update the field ID each time the block is inserted. Yes have found this problem before with attributes. So used a lisp to change the field ID. Quote
