anewman Posted February 9, 2009 Posted February 9, 2009 Where abouts is the pen table? Is the area you mean the one I have attached? Thanks Andy Quote
Bogbadbob658 Posted February 9, 2009 Posted February 9, 2009 Are you using CTB or PST plotting? If you are not sure go as if to plot and check the file name in the top right hand corner. It will end in either ctb or pst. If you can't see the file click the > at the bottom right. If you are using a ctb file then click the button to the right of the file name. You can then edit the file. I would suggest you save it with a new name so as not to effect any other drawings. Sorry if I'm teaching you to suck eggs but I'm not sure of your level of ability. Quote
anewman Posted February 10, 2009 Posted February 10, 2009 Are you using CTB or PST plotting? If you are not sure go as if to plot and check the file name in the top right hand corner. It will end in either ctb or pst. If you can't see the file click the > at the bottom right. If you are using a ctb file then click the button to the right of the file name. You can then edit the file. I would suggest you save it with a new name so as not to effect any other drawings. Sorry if I'm teaching you to suck eggs but I'm not sure of your level of ability. That worked prefectly. Thank you all very much for your help. Andy Quote
gil9166 Posted October 9, 2009 Posted October 9, 2009 use "Super Purge" command and everything is by layer Howdy folksI've got a project with an architect who doesn't use color by layer on entities and attributes. I've got a routine to change all entities and entities within blocks to color bylayer, but this doesn't help with the existing blocks with attributes in them. Can anyone supply code or tell me how to quickly change the attributes with a window or by block to be color bylayer? Many thanks! Quote
yrnomad Posted October 9, 2009 Author Posted October 9, 2009 That command wasn't recognized. How do you type it (i.e. superpurge; -superpurge...) Is it a custom lisp you have picked up somewhere else? Quote
