Hari kowshik Posted August 16 Share Posted August 16 Reading the blocks from External files using AutoCAD .NET API with c# I can read the block References using ReadDwgFile() but I am not getting the properties of the block if it is a dynamic block I am not getting the value of Visibility property instead I am getting the default value. can anyone help me with this issue? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 16 Share Posted August 16 I've barley started with C# and AutoCAD, so I am probably off target, but dealing with Dynamic Blocks in VLISP is totally different than getting regular (nondynamic) block properties. AFAIK it is the same with C#, VBA, .NET, etc. You'll need to reference something like GetDynamicBlockVisibility If my previous research wasn't faulty. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 16 Share Posted August 16 I have these bookmarked... https://stackoverflow.com/questions/46264522/working-with-dynamic-blocks-in-c-for-autocad https://stackoverflow.com/questions/42521575/accessing-autocad-dynamic-block-block-properties-table-through-c-sharp-com-int Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 17 Share Posted August 17 If you have a look at Lee-mac.com, dynamic block lisp, yes it is lisp but he has posted numerous functions to do with dynamic blocks may give you some clues and how to write an equivalent C# version. Quote Link to comment Share on other sites More sharing options...
Hari kowshik Posted August 26 Author Share Posted August 26 (edited) I have a dynamic block with 5 visibilities. I have placed each instance of the dynamic block with different Visibility so I have 5 blocks in a dwg file but when I try to read this external dwg file using the ReadDwgFile() method I am getting the Anonyms blocks for the remaining 4 instances other than the default Visibility block, how to get the original block name while reading from the External dwg file. Still, when I am reading through the Active document I can read the original block names of 5 instances, can anyone help me with this? here is the code that I am using to load the blocks from the external dwg file to the current database private static void LoadBlocksFromExternalFile(Database currentDb, string filePath, Editor ed) { try { using (Database externalDb = new Database(false, true)) { externalDb.ReadDwgFile(filePath, FileShare.Read, true, ""); ObjectIdCollection blockIds = new ObjectIdCollection(); using (Transaction tr = externalDb.TransactionManager.StartTransaction()) { BlockTable externalBt = (BlockTable)tr.GetObject(externalDb.BlockTableId, OpenMode.ForRead); foreach (ObjectId btrId in externalBt) { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead); if (!btr.IsLayout) { string blockName; // Check if the block is anonymous if (btr.IsAnonymous) { blockName = btr.Name; // Use the anonymous name directly ed.WriteMessage($"\nAnonymous Block \"{blockName}\" loaded from file."); } else { // Create a temporary BlockReference to get the block name BlockReference tempBlockRef = new BlockReference(Point3d.Origin, btrId); blockName = tempBlockRef.IsDynamicBlock ? ((BlockTableRecord)tempBlockRef.DynamicBlockTableRecord.GetObject(OpenMode.ForRead)).Name : btr.Name; if (tempBlockRef.IsDynamicBlock) { ed.WriteMessage($"\nBlock \"{blockName}\" is a dynamic block."); } ed.WriteMessage($"\nBlock \"{blockName}\" loaded from file."); } blockIds.Add(btrId); } } tr.Commit(); } if (blockIds.Count > 0) { IdMapping mapping = new IdMapping(); currentDb.WblockCloneObjects(blockIds, currentDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false); } } } catch (System.Exception ex) { Application.ShowAlertDialog($"Error loading blocks from file: {ex.Message}"); } } Edited August 26 by SLW210 Added Code Tags!! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 26 Share Posted August 26 Please use Code Tags. (the <> in the editor toolbar) I merged your threads, please keep related topics in 1 thread. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 26 Share Posted August 26 Was trying to use VLISP for this, but I also looking into VBA and C#. You may need to go to a more C# specialized forum, though any .NET should be similar enough. Did you even bother looking at the links I posted? Giles is still around on Autodesk Forum and maybe other sites AFAIK. Really just starting with C# and AutoCAD, but from what I have researched you need something along these lines, more of a guideline than working code. using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.Geometry; public class BlockVisibilityStates { [CommandMethod("ReadVisibilityStates")] public void ReadVisibilityStates() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; // Start a transaction using (Transaction tr = db.TransactionManager.StartTransaction()) { // Open the BlockTable for read BlockTable blkTbl = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); // Iterate through each block in the BlockTable foreach (ObjectId blkId in blkTbl) { BlockTableRecord blkRec = (BlockTableRecord)tr.GetObject(blkId, OpenMode.ForRead); // Check if it's a dynamic block if (blkRec.IsDynamicBlock) { // Iterate through the block references foreach (ObjectId objId in blkRec) { if (objId.ObjectClass.Name == "AcDbBlockReference") { BlockReference blkRef = (BlockReference)tr.GetObject(objId, OpenMode.ForRead); // Get the dynamic block reference property collection DynamicBlockReferencePropertyCollection propCollection = blkRef.DynamicBlockReferencePropertyCollection; foreach (DynamicBlockReferenceProperty prop in propCollection) { if (prop.PropertyName == "Visibility") { // Read the visibility state var visibilityState = prop.Value.ToString(); doc.Editor.WriteMessage($"Block: {blkRec.Name}, Visibility State: {visibilityState}\n"); } } } } } } // Commit the transaction tr.Commit(); } } } Untested 1 Quote Link to comment Share on other sites More sharing options...
