I finally found which lisp is causing me problems on my startup suite. Can anyone who knows something about lisp tell me why when this lisp loads it asks for me to select object to scale and stops the rest of the lsps in the startup suite from loading. any help would be great
;; This lisp breaks a two lines which cross each other
(defun c:sc ()
(setq pick (entsel "\nPick:")) (terpri)
(setq pnt (getpoint "\nPick point:" )) (terpri)
(setq scl (getstring "0.5"))
(command "scale" pick pnt scl )
(defun c:half ()
(prompt
  "\nPick entities you want to scale: ")
  (setq ss (ssget))
(setq pt (getpoint "\n Pick scale point: "))
(command "scale" ss "" pt 0.5)
(defun c:twice ()
(prompt
  (setq ss (ssget))
(command "scale" ss "" pt 2)
(defun c:1QUARTER ()
(prompt
  (setq ss (ssget))
(command "scale" ss "" pt 0.25)
(defun c:three4 ()
(prompt
  (setq ss (ssget))
(command "scale" ss "" pt 0.75)
defun c:alberto ()
(prompt
  (setq ss (ssget))
(command "scale" ss "" pt 1.5)
This one aaa lets you scale reference
(defun c:aaa ()
(command "OSNAP" "ins")
(SETQ object (entsel "\n pick object"))
(SETQ INS (GETPOINT "\NPICK POINT"))
(command "scale" object "" INS "R" "6-1/64" "4.5")
(command "osmode" "0")
(defun c:vsc ()
(prompt
  (setq ss (ssget))
(command "scale" ss "" pt tom)
(defun c:t0 ()
(command "style" "" "" 0 "" "" "" "" ""))
Sounds like it has commands outside of the defined function (defun) - post it on here and I should be able to sort it for ya :)
oops, i meant to post that origionally
try this it has a few problems
(defun c:sc ()
(defun c:half ()
(prompt
  (setq ss (ssget))
(defun c:twice ()
(prompt
  (setq ss (ssget))
(prompt
  (setq ss (ssget))
(defun c:three4 ()
(prompt
  (setq ss (ssget))
(defun c:alberto ()
(prompt
  (setq ss (ssget))
;;This one aaa lets you scale reference
(defun c:aaa ()
(defun c:vsc ()
(prompt
  (setq ss (ssget))
(defun c:t0 ()
After quick glance - just tidied em up a bit:
(defun c:sc  (/ pick pnt scl)
   pnt  (getpoint "\nPick point:")
 (command "scale" pick pnt scl)
 (princ))
(defun c:half  (/ ss pt)
 (prompt "\nPick entities you want to scale: ")
 (setq    ss (ssget)
 (princ))
(defun c:twice    (/ ss pt)
 (setq    ss (ssget)
 (princ))
(defun c:1QUARTER  (/ ss pt)
 (prompt
 (setq    ss (ssget)
 (princ))
(defun c:three4     (/ ss pt)
 (setq    ss (ssget)
 (princ))
(defun c:alberto  (/ ss pt)
 (setq    ss (ssget)
 (princ))
(defun c:aaa  (/ object ins)
 (princ))
(defun c:vsc  (/ ss pt)
 (setq    ss (ssget)
 (princ))
(defun c:t0  ()
 (princ))
[a few could be written better imo] :P
i know... i didnt write any of these, i dont even use these... my office is afraid of change, even though i dont think anyone uses these anymore if i get rid of a file they freak, so i figured i would try to get it so it works without causing problems...
I know exactly what you mean - the office I worked at was the same... only difference was that only one of them out of abour 10 had even heard of macros, DIESEL or LISP. :(
I actually have it the other way, my company is somewhat nudging me to learn C++ so I can maintain our scripts (for add-on hasbCAD) in the event my colleague (who writes said scripts) should succumb to the "hit by a bus" scenario. Unfortunately, the only actual coding I've ever done was making my Tandy beep out the Für Elise in QBASIC...
There's a designer (sic) here with 15+ years experience w/ cadd that refuses to use anything that isn't OOTB; no lisp, no pgp, he has to pick the commands from icons, he won't even use the wheel on his mouse to pan/zoom. It's hard to try to implement anything progressive (e.g. annotative text, dynamic blocks) when people refuse to try and learn. To each their own I guess...
Oops, I didn't mean to hijack the thread.
glad to know im not alone with this
I think this explains a lot...
Yeh, apologies for thread hijack...
Btw, parenthesis mistakes can be easily spotted using the Visual LISP Editor in ACAD - (type VLIDE at command line).
Click "Format" to perform a parenthesis check and line the code up nicely :)
