fromMlm Posted August 23 Share Posted August 23 I found this nice revision cloud lisp made by Lee Mac: (defun c:rv ( / *error* ar bn cm el fn rv ) (setq bn "revlsp") ;; Rev Cloud Attributed Block (defun *error* ( msg ) (if cm (setvar 'cmdecho cm)) (if ar (setvar 'attreq ar)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq cm (getvar 'cmdecho) ar (getvar 'attreq) ) (cond ( (not (or (tblsearch "BLOCK" bn) (and (setq fn (findfile (strcat bn ".dwg"))) (progn (setvar 'cmdecho 0) (command "_.-insert" fn nil) (setvar 'cmdecho cm) (tblsearch "BLOCK" bn) ) ) ) ) (princ (strcat "\n" bn ".dwg not found.")) ) ( (zerop (logand 2 (cdr (assoc 70 (tblsearch "BLOCK" bn))))) (princ (strcat "\n" bn " not attributed.")) ) ( (setq *rev* (cond ( (= "" (setq rv (getstring t (strcat "\nSpecify Revision" (if *rev* (strcat " <" *rev* ">: ") ": "))))) *rev* ) ( rv ) ) ) (initcommandversion) (command-s "_.revcloud") (while (= 1 (logand 1 (getvar 'cmdactive))) (command "\\")) (setvar 'cmdecho 0) (setvar 'attreq 0) (setq el (entlast)) (command "_.-insert" bn "_S" 1.0 "_R" 0.0 "\\") (if (not (eq el (setq el (entlast)))) (progn (setq el (entget (entnext el))) (if (entmod (subst (cons 1 *rev*) (assoc 1 el) el)) (entupd (cdr (assoc -1 el))) ) ) ) (setvar 'attreq ar) (setvar 'cmdecho cm) ) ) (princ) ) (princ) What I wish to do is: 1. Set the insertion point with variable rotation using osnap nearest and then back to current osnaps 2. - Save current layer/working layer. - Then temporarily change to a new given layer but change colour on the revision cloud to cyan (not the block) - Do the revision cloud and the insert. - Finally change back to my working layer. (in my case "K596 - Revideringsmoln") REVLSP.dwg I have tried to delete the 0.0 (command "_.-insert" bn "_S" 1.0 "_R" "\\") It just allows me to rotate the block and then place it. And the revision do not show. I would like to place first and then rotate. How do I specify the insert point for the block so I can rotate it? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 24 Share Posted August 24 "How do I specify the insert point for the block so I can rotate it?" A block is normally rotated around its insertion point when using "INSERT" you can rotate a block after its inserted and have a different base point for the rotation. So if you know the block relationship to a new base point and insertion point then yes can be done via a simple lisp.Insert then rotate. Quote Link to comment Share on other sites More sharing options...
fromMlm Posted August 24 Author Share Posted August 24 Thanks for the replay BIGAL! What I wished for was to use Lee Macs revision lisp and modify it, so I can rotate my revision block. This part in the lisp seems to be the part I have to modify: (command "_.-insert" bn "_S" 1.0 "_R" 0.0 "\\") If I understand this part of the code, 0.0 is a fixed angle. So I deleted 0.0 to see if it made the rotation flexible. But it didn't quite do what I wanted...(the revison didn't shoe e.g.) Do I need to create another variable like "pt" and put it into the code above? Or how do I alter this code part to suite what I wish for? Here is an example I found where pt is present : (setq pt (getpoint "\nSpecify insertion point (or Enter to stop) : \n")) (command "-insert" bname pt 1 1 0) Quote Link to comment Share on other sites More sharing options...
fromMlm Posted September 2 Author Share Posted September 2 Hi again Is there anybody who could help me tweak the above menstioned Lisp? I think it must be this row that has to be altered. (command "_.-insert" bn "_S" 1.0 "_R" 0.0 "\\") Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 2 Share Posted September 2 You can use pause to enter angle or something like this allows onscreen dragging of angle. (command-s "_.-insert" bn "_S" 1.0 (getpoint "\nPick point for insertion ")) Quote Link to comment Share on other sites More sharing options...
fromMlm Posted September 3 Author Share Posted September 3 thanks for the reply! I will look into it. Quote Link to comment Share on other sites More sharing options...
fromMlm Posted September 9 Author Share Posted September 9 Thanks!! Works like I wish now. Quote Link to comment Share on other sites More sharing options...
