7empest Posted September 4 Author Posted September 4 (edited) 19 hours ago, BIGAL said: You are right ignore Item 1 comment that is is mid point between 2 points. If you want the text further inside the lots need to rework out the text position. Change the 1.1 or change the (* 1.1 ts) to a offset distance. eg 2.5 number only no brackets. (vla-put-TextAlignmentPoint to (vlax-3D-point (polar m (+ ta (/ pi 2.)) (* 1.1 ts)))) (vla-put-TextAlignmentPoint to (vlax-3D-point (polar m (+ ta (/ pi 2.)) 2.5))) You're a genius! It worked! Now, for some reason I am still only getting whole numbers appearing as 1 decimal place again. I feel like it almost has a mind of its own. I have attached the code in case I am missing something obvious. Edit: I've tried it on a different file and suddenly it shows it to 2 decimal places on whole numbers. I'll keep playing around with it until i can find the cause Edit 2: okay found the fix.. it only happened when I started a new drawing. So what i needed to do was to do a single dimension with 2 decimal places THEN the lsp will recognize the dim at 2 value.. Not sure why but it fixed the issue. Lol ;;-------------=={ Length Between Intersections }==-----------;; ;; ;; ;; Displays the length of segments of a curve divided at ;; ;; intersections with other objects. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Version 1.4 - 26-04-2011 ;; ;;------------------------------------------------------------;; (defun c:IntLen ( / *error* _iscurveobject e ) (defun *error* ( msg ) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (defun _IsCurveObject ( entity / param ) (and (not (vl-catch-all-error-p (setq param (vl-catch-all-apply 'vlax-curve-getendparam (list entity)) ) ) ) param ) ) (if (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER)))))) (princ "\n--> Current Layer Locked.") (while (progn (setvar 'ERRNO 0) (setq e (car (entsel))) (cond ( (= 7 (getvar 'ERRNO)) (princ "\n--> Missed, Try again.") ) ( (eq 'ENAME (type e)) (if (_iscurveobject e) (LM:IntersectionLengths e) (princ "\n--> Invalid Object Selected.") ) t ) ) ) ) ) (princ) ) ;;------------------------------------------------------------;; (defun c:IntLenM ( / *error* ss i ) (defun *error* ( msg ) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (if (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER)))))) (princ "\n--> Current Layer Locked.") (if (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")))) (repeat (setq i (sslength ss)) (LM:IntersectionLengths (ssname ss (setq i (1- i)))) ) ) ) (princ) ) ;;------------------------------------------------------------;; (defun LM:IntersectionLengths ( e ;; Entity name / *error* _startundo _endundo _groupbynum _sortbyparam _makereadable _isannotative _uniquefuzz a acspc c d d1 d2 da e i l ll m o ss ta to ts ur x y ) (setq acdoc (cond ( acdoc ) ( (vla-get-activedocument (vlax-get-acad-object)) )) acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace)) ) (defun *error* ( msg ) (if acdoc (_EndUndo acdoc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (defun _StartUndo ( doc ) (_EndUndo doc) (vla-StartUndoMark doc) ) (defun _EndUndo ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndoMark doc)) ) (defun _GroupByNum ( l n / r) (if l (cons (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r)) (_GroupByNum l n) ) ) ) (defun _SortbyParam ( e l ) (vl-sort l '(lambda ( a b ) (< (vlax-curve-getParamatPoint e a) (vlax-curve-getParamatPoint e b)))) ) (defun _MakeReadable ( a ) ( (lambda ( a ) (cond ( (and (> a (/ pi 2)) (<= a pi)) (- a pi) ) ( (and (> a pi) (<= a (/ (* 3 pi) 2))) (+ a pi) ) ( a ) ) ) (rem a (* 2 pi)) ) ) (defun _isAnnotative ( style / object annotx ) (and (setq object (tblobjname "STYLE" style)) (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse annotx)))) ) ) (defun _uniquefuzz ( lst fuzz ) (if lst (cons (car lst) (_uniquefuzz (vl-remove-if '(lambda ( x ) (equal x (car lst) fuzz)) (cdr lst)) fuzz ) ) ) ) (setq ts (/ (getvar 'textsize) (if (_isAnnotative (getvar 'textstyle)) (cond ( (getvar 'cannoscalevalue) ) ( 1.0 )) 1.0 ) ) ) (_StartUndo acdoc) (vla-getBoundingBox (setq o (vlax-ename->vla-object e)) 'll 'ur) (mapcar '(lambda ( x ) (set x (vlax-safearray->list (eval x)))) '(ll ur)) (if (setq l (_sortbyparam e (_uniquefuzz (apply 'append (repeat (setq i (sslength (ssdel e (setq ss (ssget "_C" (trans ur 0 1) (trans ll 0 1) '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))) ) ) ) ) (setq l (cons (_groupbynum (vlax-invoke o 'intersectwith (vlax-ename->vla-object (ssname ss (setq i (1- i)))) acextendnone ) 3 ) l ) ) ) ) 1e-8 ) ) ) (if (not (vlax-curve-isClosed e)) (progn (or (equal (vlax-curve-getStartParam e) (vlax-curve-getParamatPoint e (car l)) 0.001) (setq l (cons (vlax-curve-getStartPoint e) l)) ) (or (equal (vlax-curve-getEndParam e) (vlax-curve-getParamatPoint e (last l)) 0.001) (setq l (append l (list (vlax-curve-getEndPoint e)))) ) ) (setq c l) ) (if (vlax-curve-isClosed e) (setq l (list (vlax-curve-getStartPoint e)) c l) (setq l (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e))) ) ) (while (cadr l) (setq x (car l) y (cadr l) l (cdr l)) (setq m (vlax-curve-getPointatDist e (/ (+ (vlax-curve-getDistatPoint e y) (vlax-curve-getDistAtPoint e x)) 2.) ) ) (setq d (abs (- (vlax-curve-getDistatPoint e y) (vlax-curve-getDistAtPoint e x)) ) ) (setq a (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv e (vlax-curve-getParamatPoint e m)) ) ) (setq ta (_makereadable a)) (setq to (vla-AddText acspc (rtos d 2 2) (vlax-3D-point '(0. 0. 0.)) ts)) (vla-put-Alignment to acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint to (vlax-3D-point (polar m (+ ta (/ pi 2.)) 0))) (vla-put-rotation to ta) ) (if (vlax-curve-isclosed e) (progn (if (= 1 (length c)) (setq c (append c c))) (setq d (+ (setq d1 (vlax-curve-getDistatPoint e (car c))) (setq d2 (- (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) (vlax-curve-getdistatpoint e (last c)))) ) ) (setq m (vlax-curve-getPointatDist e (if (< d1 (setq da (/ (+ d1 d2) 2.))) (setq da (- (vlax-curve-getdistatparam e (vlax-curve-getendparam e)) (- da d1))) (setq da (- da d2)) ) ) ) (setq a (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv e (vlax-curve-getParamatPoint e m)) ) ) (setq ta (_makereadable a)) (setq to (vla-AddText acspc (rtos d 2 2) (vlax-3D-point '(0. 0. 0.)) ts)) (vla-put-Alignment to acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint to (vlax-3D-point (polar m (+ ta (/ pi 2.)) 0))) (vla-put-rotation to ta) ) ) (_EndUndo acdoc) (princ) ) ;;------------------------------------------------------------;; (vl-load-com) (princ) (princ "\n:: IntLen.lsp | Version 1.4 | © Lee Mac 2011 www.lee-mac.com ::") (princ "\n:: Type \"IntLen\" or \"IntLenM\" to Invoke ::") (princ) ;;------------------------------------------------------------;; ;; End of File ;; ;;------------------------------------------------------------;; Edited September 4 by 7empest Quote
BIGAL Posted September 5 Posted September 5 Check your dimstyle make sure it has say the Dim Precision set to 0.00. Quote
