basty Posted August 20, 2024 Posted August 20, 2024 I would like to edit the "Start and End tangent vector Y" of a Spline in ACAD 2014. To do that, I need to select the Spline and go to Properties palette. Unfortunately, the option in the Properties palette is blank (see attached image below please). How do I solve this problem? Thank you Quote
BIGAL Posted August 20, 2024 Posted August 20, 2024 (edited) If I understand correctly, need to move end points down, what happens when you drag using grips, does it work ? Post dwg. Edited August 20, 2024 by BIGAL Quote
SLW210 Posted August 21, 2024 Posted August 21, 2024 What is your Operating System? AutoCAD 2014 is 11 version ago and latest official OS is Windows 8.1. Quote
basty Posted August 21, 2024 Author Posted August 21, 2024 (edited) 13 hours ago, BIGAL said: If I understand correctly, need to move end points down, what happens when you drag using grips, does it work ? Post dwg. I don't understand what you're saying. Here is the .dwg file. 1 hour ago, SLW210 said: What is your Operating System? AutoCAD 2014 is 11 version ago and latest official OS is Windows 8.1. It's a Windows 7 Pro SP1. Spiral_-_Alike_for_CADTutor.dwg Edited August 21, 2024 by basty Quote
SLW210 Posted August 21, 2024 Posted August 21, 2024 Works fine here on AutoCAD 2024. Like I said, AutoCAD 2014 is 11 version old, with no updates in a while, same goes for Windows 7 about 9 years since latest update IIRC. You haven't mentioned what you have tried so far. Restart AutoCAD and maybe Windows. Try a new profile. Reset AutoCAD settings to default. Repair AutoCAD. Reinstall AutoCAD. Could be Graphics or Computer issue as well. Quote
