Konstantinos Mantzanas Posted August 17, 2024 Posted August 17, 2024 Hello, i have imported some points that are georeferenced. i have created a design with 1:1 scale, but i want to print it in a scale of 1:200 and when i create a Layout with costum scale of 0.005 my design comes out as extremely small relative to the Layout Any ideas why this is happening? Thank you in advance. Quote
eldon Posted August 19, 2024 Posted August 19, 2024 You have not mentioned what units you are using in your drawing. I am guessing that you would be using metre units. The AutoCAD default metric plotting units are millimetres. This means that a scaling of 1000 has to be introduced into the working somewhere. If you have used a custom scale of 0.005 in Layout and your design appears very small, then alter the custom scaling to 0.005 x 1000= 5 and see what that looks like. Another way of getting a scale is to try plotting to fit, and then alter the scaling, that is shown, to be a round number. Otherwise, post your drawing and someone can have a proper look at how it is set up. 1 Quote
BIGAL Posted August 19, 2024 Posted August 19, 2024 Another comment if the objects are in metres then 5 would be correct, for mm 0.005. In Autocad turn on the viewports toolbar this has a little box that indicates current scale so we set our title block to true size eg A1 820x570 when measured, then a mview inside that, if you zoom making the objects say close to fitting the mview, in the box will be a number you should see like 4.678, change to 5, 6.1 change to 5 or 10 and so on. Hope it makes sense. Scales 1000/x 1000/200=5 1 Quote
Konstantinos Mantzanas Posted August 21, 2024 Author Posted August 21, 2024 Thank you a lot for your help. i am using meters. I worked it out though. Many thanks. Quote
