Mack062 Posted November 16, 2011 Posted November 16, 2011 I draw all my drawings in model space 1-1. Full size and then scale the layouts in paperspace to suit. I have never scaled drawings in model space. Will this hatch pattern work using 1 - 1? Quote
BIGAL Posted November 17, 2011 Posted November 17, 2011 Again using a pline you dont have any problems with height v's fixed patterning in a hatch, the pline lisp asks what height is the batting and draws it to suit, its coded around a normal height solution to start with if the batting was super sized the a different batt.lsp would be used to still give the correct artistic look, like Remark how good do you want it to look ? Quote
Bill Tillman Posted December 20, 2011 Posted December 20, 2011 Hey that's pretty cool. There are some very nice LISP programs available to do batt insulation hatching. Do some searches for this at Cadalyst.com's website and you'll find some good ones there. Quote
Manila Wolf Posted December 31, 2011 Posted December 31, 2011 (edited) The attached "BattInsulation" hatch pattern at the bottom of this post is quite a good one. Best to set the hatch start point at Bottom Left, Bottom right, Top left or Top right, then play with the scale to suit. Looks like this: - Personally, I still prefer to use a lisp for adding the Insulation pattern. The best lisp in my opinion can be found here: - http://autodesk.lithium.com/t5/Visual-LISP-AutoLISP-and-General/Insulation-Batt-representation-in-Polyline-form/td-p/2458785/page/2 Nice feature is that you can follow arcs and circles with this. Some features (Pic by the lisp author): - BattInsulation.txtFetching info... Edited December 31, 2011 by Manila Wolf Added Note about hatch start position, then added pics. 1 Quote
slara Posted February 4, 2012 Posted February 4, 2012 This is great, but why does it not work as a model hatch? Any ideas??? Quote
molasses Posted February 24, 2012 Posted February 24, 2012 It does work as a model space hatch (I'm assuming that's what you meant) but the scale is weird. A hatch scale of .055 results in a 5.5" thick batt. Make the hatch scale too small or too big and it appears as a solid. Quote
quosaihuska Posted August 28, 2014 Posted August 28, 2014 hi, I am using ACAD 2013 in Mac, I am trying to insert a BATT insulation pattern, anyone knows how? Quote
ReMark Posted August 28, 2014 Posted August 28, 2014 Use the Hatch command would seem to be the obvious answer. Or is it? Are you trying to add a new hatch pattern either in your acad.pat file or on its own? Quote
darwinland Posted October 27, 2016 Posted October 27, 2016 This pattern doesnt work on my autocad 2016, could be an incompatiblity with this version of cad? Quote
Spiderguy Posted October 27, 2016 Author Posted October 27, 2016 (edited) I hope that it's something that can be resolved! Are there any others that are having this problem? I am currently using 2014 and have no issues with the BATT.pat hatch, it works as I had envisioned. We are supposed to upgrade to the latest greatest version soon, if I have problems I will try to figure out what is going on, however, if anyone here can help darwinland with this problem, that would be awesome! To answer the question about scaling, yes this works in 1 to 1, and is not affected by changing the scale of the drawing (as the line type does), I'm not sure about the lisp routine that the page 5 link refers to. this has always worked by inserting the hatch and the scale is, for example, if I am filling a 2x4 stud wall nominal 3-1/2" then you would change the scale to 3.5, your origin point should be at the lower right hand side, or anywhere along one of the sides, it is set so the the angle is proper for filling a vertical area (wall), if you are trying to fill something at a 0 degree angle, then you have to subtract 90 from the angle you need. In my opinion, it's pretty simple, but then it was created according to my plans on using it, so I may be biased! I am sorry that I did not answer the previous posts, for some reason I was not getting notifications. Edited October 27, 2016 by Spiderguy Quote
