Can I set up Navisworks review with colors so I can see clashes easily? Someone sent us all the clashes and its hard to tell where they are..Ive seen it set up where everything is grey except for the clash...
Do you have the full version of NavisWorks or are you using the Freedom viewer? It sounds like you may be using the Freedom viewer which does not do the grey / red thing. If you have the full version than I am not sure why it would not be showing up as grey / red.
