ROUTINE CUMULATIVE DISTANCES HELP...
leonucadomi
hello all:
I found this good routine here,
(defun c:cd ()
(setvar "cmdecho" 0)
(graphscr)
(setq
 p1 (getpoint "\nPick start point ")
 p2 (getpoint p1 "\nPick next point ")
 d1 (distance p1 p2)
 prdist (strcat "\nDistance: " (rtos d1 2 0))
(princ prdist)
(setq p3 (getpoint p2 "\nPick next point or RETURN if done "))
(while p3
 (setq
  d0 (distance p2 p3)
  d1 (+ (distance p2 p3) d1)
  p2 p3
  prdist (strcat "\nDistance: " (rtos d0 2 0) ", Cumulative distance: " (rtos d1 2 0))
 (princ prdist)
 (setq p3 (getpoint p2 "\nPick Next Point "))
(setq cumd (strcat "Cumulative distance --> " (rtos d1 2 0)))
(prompt cumd)
I hope someone can help
thanks
Edited by leonucadomi
With this modification?
(defun c:cd ( / p1 p2 d1 prdist p3 d0 cumd)
  (graphscr)
  (setq
    d1 (abs (- (car p2) (car p1)))
  (princ prdist)
  (while p3
    (setq
      d0 (abs (- (car p3) (car p2)))
      d1 (+  (abs (- (car p3) (car p2))) d1)
      p2 p3
    (princ prdist)
  (prompt cumd)
  • Thanks 1
Why not
  (while p3
(while (setq p3 (getpoint p2 "\nPick next point or RETURN if done "))
This is what I use:
(defun c:mdist (/ n p1 p2 d v)
  (setq d 0 n 0)
  (while (and (or p1 (setq p1 (getpoint "\nSpecify start point: ")))
	      (setq p2 (getpoint p1 "\nSpecify next point: "))
    (setq d  (+ d (distance p1 p2))
	  v  (append v (list (setq n (1+ n)) p1 p2))
	  p1 p2
    (grvecs v)
    (princ (strcat "\nRunning total is " (rtos d)))
Edited by ronjonp
  • Thanks 1
