Hy
I m new in 3D autocad.I need help about trim in 3D.Can somebody help me about this(i use Autocad 2008.Thanks
Dean
I would recommend the use of the SLICE command. The AutoCAD Help files provides instructions for its use. Fairly simple.
Thak you,thank you,thank you...it Works!!
You're welcomed, you're welcomed, you're welcomed! I'm so happy it did the trick for you I'm going to take the rest of the day off.:lol:
