Darrell Posted August 8 Share Posted August 8 I need a lisp that will find blocks of a specific name in a drawing and move them all to a certain layer. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 8 Share Posted August 8 Give this a try, assuming they are not modified dynamic blocks. (defun c:foo (/ s) (if (setq s (ssget "_X" '((0 . "INSERT") (2 . "YOURBLOCKNAME")))) (foreach e (mapcar 'cadr (ssnamex s)) (entmod (append (entget e) '((8 . "YOURLAYERNAME"))))) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
Darrell Posted August 8 Author Share Posted August 8 49 minutes ago, ronjonp said: Give this a try, assuming they are not modified dynamic blocks. (defun c:foo (/ s) (if (setq s (ssget "_X" '((0 . "INSERT") (2 . "YOURBLOCKNAME")))) (foreach e (mapcar 'cadr (ssnamex s)) (entmod (append (entget e) '((8 . "YOURLAYERNAME"))))) ) (princ) ) Thanks I'll give it a try! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 9 Share Posted August 9 (edited) Hope you don't mind @ronjonp just added get name and layer by object. (defun c:foo2 ( / s bname) (setq bname (cdr (assoc 2 (entget (car (entsel "\nPlease pick block for name search ")))))) (setq lay (cdr (assoc 8 (entget (car (entsel "\nPlease pick any object for destination layer ")))))) (if (setq s (ssget "_X" (list (cons 0 "INSERT") (cons 2 bname)))) (foreach e (mapcar 'cadr (ssnamex s)) (entmod (append (entget e) (list (cons 8 lay))))) ) (princ) ) Can also use CHPROP on selection set s, I think the foreach may be faster though. Edited August 9 by BIGAL Quote Link to comment Share on other sites More sharing options...
