yawdapaah Posted March 26, 2009 Posted March 26, 2009 Hello, I have a problem with a lisp routine used by my company. I am new to autocad/lisps and am just beginning to learn it so was wondering if someone could help me out; ------- (defun C:CX (/ eprLayFilt lstTemp lstFilters enaFilter) (setvar "cmdecho" 0) (command "_.undo" "be") (setvar "tilemode" 1) (command "zoom" "e") (command ".LAYER" "A" "S" "ORIGINAL" "" "" "C" "8" "*" "A" "S" "PRINT" "" "" "" ) (command "graphscr") (command ".LAYER" "U" "*" "") (zflatten) (setq i -1) (repeat (sslength (setq ss (ssget "x" '((-4 . "/=") (62 . 256))))) (entmod (subst '(62 . 256) (assoc 62 (setq elist (entget (ssname ss (setq i (1+ i)))))) elist)) ) (command ".LAYER" "A" "R" "ORIGINAL" "" "" "") (vl-load-com) (vlax-for ps (vla-get-plotconfigurations (vla-get-activedocument (vlax-get-acad-object))) (vla-delete ps)) (setq eprLayFilt (entget (cdr (assoc 360 (entget (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "LAYER" "0")))))))))))) (foreach lstTemp eprLayFilt (if (= (car lstTemp) 360) (progn (princ lstTemp) (setq lstFilters (append lstFilters (list (cdr lstTemp)))) ) ) ) (if lstFilters (foreach enaFilter lstFilters (entdel enaFilter)) ) (setvar "indexctl" 3) (repeat 3 (command "purge" "a" "*" "n")) (command "audit" "y") (command "_.undo" "e") (setvar "cmdecho" 1) (princ) ) ----- Sometimes it returns an error: error: bad argument type: lselsetp nil thanks Quote
Lee Mac Posted March 26, 2009 Posted March 26, 2009 That error means that your selection set is nil, try this for a quick fix: (defun C:CX (/ eprLayFilt lstTemp lstFilters enaFilter) (setvar "cmdecho" 0) (command "_.undo" "be") (setvar "tilemode" 1) (command "zoom" "e") (command ".LAYER" "A" "S" "ORIGINAL" "" "" "C" "8" "*" "A" "S" "PRINT" "" "" "") (command "graphscr") (command ".LAYER" "U" "*" "") (zflatten) (setq i -1) (if (setq ss (ssget "x" '((-4 . "/=") (62 . 256)))) (progn (repeat (sslength ss) (entmod (subst '(62 . 256) (assoc 62 (setq elist (entget (ssname ss (setq i (1+ i)))))) elist)) ) (command ".LAYER" "A" "R" "ORIGINAL" "" "" "") (vl-load-com) (vlax-for ps (vla-get-plotconfigurations (vla-get-activedocument (vlax-get-acad-object))) (vla-delete ps)) (setq eprLayFilt (entget (cdr (assoc 360 (entget (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "LAYER" "0")))))))))))) (foreach lstTemp eprLayFilt (if (= (car lstTemp) 360) (progn (princ lstTemp) (setq lstFilters (append lstFilters (list (cdr lstTemp)))) ) ) ) (if lstFilters (foreach enaFilter lstFilters (entdel enaFilter)) ) (setvar "indexctl" 3) (repeat 3 (command "purge" "a" "*" "n")) (command "audit" "y") (command "_.undo" "e") (setvar "cmdecho" 1)) (princ "\n<!> Nothing Found <!>")) (princ) ) Quote
