There is a program
Kent Cooper, but unfortunately it doesn't work. I choose a circle (or an arc). It ends with an error...
Please tell me where the error is.
(defun C:FMR (/ aper pt); = Fillet Match Radius [of existing curve]
; to apply the radius of a selected curved object in the Fillet command
; Kent Cooper, June 2011
(setq aper (getvar 'aperture))
(while
(not (setq pt (cadr (entsel "Select curve to set Fillet Radius: "))))
(prompt "\nNothing selected -- ")
); end while
(setvar 'aperture (getvar 'pickbox)); ensures Osnap won't "see" wrong thing
(if (osnap pt "cen")
(setvar 'filletrad (distance (osnap pt "nea") (osnap pt "cen"))); then
(progn ; else
(prompt "\nNo radius for that object.")
(setvar 'aperture aper)
(exit)
); end progn
); end if
(command "_.fillet" "_mUltiple")
; Select curve to set Fillet Radius:
; No radius for that object.; error: end/exit abort
Kent Cooper is active on the Autodesk Forums.
The only way the function can produce that error message is if the object chosen has no center point. It won't reach that test until you've selected an object of some kind--not necessarily an arc/circle.
Can't diagnose it any better until we know what you're picking. Note that the aperture changes while the function is active.
The program asks me to select a curve to indicate the radius of the fillet, I select a circle, but the program ends...
A quick example written from Mobile.
(setq obj (car (entsel "\nSelect circle:")))
(setvar 'filletrad (cdr(assoc 40 (entget obj))))
  • Thanks 1
And if you internationalize the parameters of (osnap)
"cen" -> "_cen"
"near" -> "_near"
This might work!
Otherwise you can try this:
(defun c:set_fillet ( / ent dxf_ent typ_ent mkv vector vlaobj id_rad)
  (while (not (setq ent (entsel "Select curve to set Fillet Radius: "))))
  (setq typ_ent (cdr (assoc 0 (setq dxf_ent (entget (car ent))))))
  (cond
    ((or
      (eq typ_ent "ARC")
      (eq typ_ent "CIRCLE")
      (eq typ_ent "LWPOLYLINE")
      (and
        (eq typ_ent "POLYLINE")
        (zerop (boole 1 120 (cdr (assoc 70 dxf_ent))))
      (if (or (> (fix (car (trans (cadr ent) 1 0))) 1E6) (> (fix (cadr (trans (cadr ent) 1 0))) 1E6))
        (setq mkv T vector (trans (cadr ent) 0 0 T) vlaobj (vlax-ename->vla-object (car ent)))
        (setq mkv nil)
      (if mkv (vla-move vlaobj (vlax-3d-point (trans (cadr ent) 1 0)) (vlax-3d-point '(0.0 0.0 0.0))))
      (setq id_rad
        (distance
          '(0 0)
          (trans
            (vlax-curve-getsecondderiv (car ent)
              (vlax-curve-getparamatpoint (car ent)
                (vlax-curve-getclosestpointto (car ent) (if mkv '(0.0 0.0 0.0) (trans (cadr ent) 1 0)))
            0
            (car ent)
            T
      (if mkv (vla-move vlaobj (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point vector)))
      (setvar "FILLETRAD" (abs id_rad))
    (T (setvar "FILLETRAD" 0.0))
  (command "_.fillet" "_multiple")
  (prin1)
"cen" -> "_cen"
"near" -> "_near"
This might work!
; by Kent Cooper
(while
); end while
;(setq obj (car (entsel "\nSelect circle:")))
;(setvar 'filletrad (cdr(assoc 40 (entget obj))))
(if (osnap pt "_cen")
(setvar 'filletrad (distance (osnap pt "_nea") (osnap pt "_cen"))); then
(progn ; else
(exit)
); end progn
); end if
Now this code is working!
@Tsuky THANK YOU VERY MUCH!
                  "set_fillet" works very well!
Edited by Nikon
