Hi all,
I have a requirement to save dwgs I received from a client down to ACAD 04. However in order to do this I need to explode all of the AEC objects which are AecbDbConduit, AecbDbConduitFitting, AecbDbLabelCurve, AecbDbMvPart, AecbDbPipe and AecbDbPipeFitting.
I can select these items manually and explode them but I am not sure how to explode them programmatically. The only types that have an explode function in my VBA environment are Acad3DPolyline, AcadBlockReference, AcadExternalReference, AcadLWPolyline, AcadMInsertBlock, AcadPolygonMesh, AcadPolyline and AcadRegion.
But from what I can tell that objects I am trying to explode are not any of the above types. So how would I go about exploding them?
Thank you for any guidance you can provide.
Steve
Sub FindAllTypesNames()
   Dim oEnt As AcadEntity
   Dim TypeName As String
   TypeName = "AecbDb"
   For Each oEnt In ThisDrawing.ModelSpace
       If (InStr(1, oEnt.ObjectName, TypeName) > 0) Then
           If TypeOf oEnt Is AcadRegion Then
               ExpBlock (oEnt)
           End If
       End If
   Next
End Sub
Sub ExpBlock(ByRef BR)
   Dim varEx As Variant
   Dim BRef As AcadRegion
   Dim i As Double
   varEx = BR.Explode
   BR.Delete
   For i = 0 To UBound(varEx)
       If TypeOf varEx(i) Is AcadRegion Then
           Set BRef = varEx(i)
           ExpBlock BRef
       End If
   Next
End Sub
Just as a thought, have you tried to search on the web for "aec object explode". It brings up a good few solutions :)
OK, very good Lee Mac. So I am a Luddite :oops:
Hehe, thought you might like that :)
See here for info
Honest I have been googling that is how I found this website.
Let me try this another way. I have the AEC and MEP object enablers installed but I get UNKNOWN command when I try to use any of the AEC commands including AECOBJECTEXPLODE. I also do not see anything in the object browser of VBA to allow me to work with AEC or MEP objects.
Is there something else that I need to setup for object enablers to make these commands available to me through VBA?
