error: bad argument type: lentityp nil
Elektrik
I do not know how to create lisp codes, but find a lisp code similar to what I had in my mind, but I used ChatGPT to enhance it the way I want it. I provided the lisp script that selects entities of a specified length from the entire drawing. I wanted the following enhancements:
1-Enable multi-selection: Allow the user to make multiple selections before running the script.
2-Filter by layer: Select only the entities that are on the same layer as the selected entities.
3-Match length: For each selected entity, select all entities of the same type and length from the same layer.
Now it gives me "bad argument type: lentityp nil lisp" error. Could anyone help me with this lisp? Thanks in advance.
The original code:
;;Create by Georgi Georgiev    - TRUDY
;;Date: 09.07.2020
(defun c:sel (/)
 (vl-load-com)
 (setq clear nil)
(setq sel1 (ssget ":S" '((0 . "LWPOLYLINE,line,circle"))))
(repeat (setq i (sslength sel1))
        (setq nam (ssname sel1 (setq i (1- i))))
        (setq ent (entget nam))
        (princ (cdr (assoc 0 ent)))
            (if (= (cdr (assoc 0 ent)) "CIRCLE")
                (setq rad (cdr (assoc 40 ent)))
                (setq len (vla-get-length (vlax-ename->vla-object nam)))
(setq selall (ssget "X" (list (assoc 0 ent))))
(repeat (setq i (sslength selall))
            (setq namall (ssname selall (setq i (1- i))))
            (setq entall (entget namall))
                    (setq radall (cdr (assoc 40 entall)))
                    (setq lenall (vla-get-length (vlax-ename->vla-object namall)))
                    (if (= rad radall) (setq clear (ssadd namall sel1)) (princ))
                    (if (= len lenall) (setq clear (ssadd namall sel1)) (princ))
(sssetfirst nil clear)
The lisp code provided by ChatGPT:
(defun c:mel (/ ss1 ss2 i j eName ent layerType rad len clear)
  (vl-load-com)
  ;; Kullanıcıya çoklu seçim yapma imkanı tanı
  (setq ss1 (ssget '((0 . "LWPOLYLINE,LINE,CIRCLE"))))
  ;; Boş seçim seti oluştur
  (setq clear (ssadd nil))
  ;; Tüm seçim setinde döngü
  (setq i 0)
  (while (< i (sslength ss1))
    (setq eName (ssname ss1 i))
    (setq ent (entget eName))
    (if ent
        (setq layerType (cdr (assoc 8 ent))) ;; Layer tipi
        (cond
          ((= (cdr (assoc 0 ent)) "CIRCLE")
           ;; Tüm çizimde aynı yarıçapa ve layer'a sahip ögeleri seç
           (setq ss2 (ssget "X" (list (cons 0 "CIRCLE") (cons 40 rad) (cons 8 layerType))))
           (if ss2
               (setq j 0)
               (while (< j (sslength ss2))
                 (setq clear (ssadd (ssname ss2 j) clear))
                 (setq j (1+ j))))))
          (T
           (setq len (vla-get-length (vlax-ename->vla-object eName)))
           ;; Tüm çizimde aynı uzunluğa ve layer'a sahip ögeleri seç
           (setq ss2 (ssget "X" (list (cons 0 (cdr (assoc 0 ent))) (cons 8 layerType))))
           (if ss2
               (setq j 0)
                 (setq ent2 (entget (ssname ss2 j)))
                 (if (and ent2 (= len (vla-get-length (vlax-ename->vla-object (ssname ss2 j)))))
                   (setq clear (ssadd (ssname ss2 j) clear)))
                 (setq j (1+ j))))))))
      (princ "\nHatalı varlık algılandı."))
    (setq i (1+ i)))
  ;; Seçilen ögeleri vurgula
Edited by SLW210
Added Code Tags!!
Please see https://lee-mac.com/errormessages.html
Quote
bad argument type: lentityp <value>
A function requiring an entity argument has been passed an argument of incorrect data type with the value noted in the error message. Usually a result of passing the entget function a null entity argument.
  • Agree 1
1st answer is that ChatGP is very unreliable so many times code is totally rewritten.
2nd "selects entities of a specified length from the entire drawing" length is not a searchable property must get object 1st then can get Length property.
You dont say what you want to do with answer so just made a list of lengths.
(defun c:wow ( / ss len)
(setq ent (entsel "\nPick a object for layer "))
(setq lay (cdr (assoc 8 (entget (car ent)))))
(setq ss (ssget (list (cons 0 "LWPOLYLINE,line,circle,Arc")(cons 8 Lay))))
(if (= ss nil)
(progn (alert "You have not selected any correct objects \nWill now exit")(exit))
(setq lst '())
  (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
  (setq objname (vlax-get obj 'objectname))
  (cond
   ((= objname "AcDbArc")(setq len (vlax-get obj 'Arclength)))
   ((= objname "AcDbLine")(setq len (vlax-get obj 'length)))
   ((= objname "AcDbCircle")(setq len (vlax-get obj 'Circumference)))
   ((= objname "AcDbPolyline")(setq len (vlax-get obj 'length)))
  (setq lst (cons len lst))
  • Thanks 1
