Elektrik Posted July 28, 2024 Posted July 28, 2024 (edited) I do not know how to create lisp codes, but find a lisp code similar to what I had in my mind, but I used ChatGPT to enhance it the way I want it. I provided the lisp script that selects entities of a specified length from the entire drawing. I wanted the following enhancements: 1-Enable multi-selection: Allow the user to make multiple selections before running the script. 2-Filter by layer: Select only the entities that are on the same layer as the selected entities. 3-Match length: For each selected entity, select all entities of the same type and length from the same layer. Now it gives me "bad argument type: lentityp nil lisp" error. Could anyone help me with this lisp? Thanks in advance. The original code: ;;Create by Georgi Georgiev - TRUDY ;;Date: 09.07.2020 (defun c:sel (/) (vl-load-com) (setq clear nil) (setq sel1 (ssget ":S" '((0 . "LWPOLYLINE,line,circle")))) (repeat (setq i (sslength sel1)) (setq nam (ssname sel1 (setq i (1- i)))) (setq ent (entget nam)) (princ (cdr (assoc 0 ent))) (if (= (cdr (assoc 0 ent)) "CIRCLE") (setq rad (cdr (assoc 40 ent))) (setq len (vla-get-length (vlax-ename->vla-object nam))) ) ) (setq selall (ssget "X" (list (assoc 0 ent)))) (repeat (setq i (sslength selall)) (setq namall (ssname selall (setq i (1- i)))) (setq entall (entget namall)) (if (= (cdr (assoc 0 ent)) "CIRCLE") (setq radall (cdr (assoc 40 entall))) (setq lenall (vla-get-length (vlax-ename->vla-object namall))) ) (if (= (cdr (assoc 0 ent)) "CIRCLE") (if (= rad radall) (setq clear (ssadd namall sel1)) (princ)) (if (= len lenall) (setq clear (ssadd namall sel1)) (princ)) ) ) (sssetfirst nil clear) (princ) ) The lisp code provided by ChatGPT: (defun c:mel (/ ss1 ss2 i j eName ent layerType rad len clear) (vl-load-com) ;; Kullanıcıya çoklu seçim yapma imkanı tanı (setq ss1 (ssget '((0 . "LWPOLYLINE,LINE,CIRCLE")))) ;; Boş seçim seti oluştur (setq clear (ssadd nil)) ;; Tüm seçim setinde döngü (setq i 0) (while (< i (sslength ss1)) (setq eName (ssname ss1 i)) (setq ent (entget eName)) (if ent (progn (setq layerType (cdr (assoc 8 ent))) ;; Layer tipi (cond ((= (cdr (assoc 0 ent)) "CIRCLE") (setq rad (cdr (assoc 40 ent))) ;; Tüm çizimde aynı yarıçapa ve layer'a sahip ögeleri seç (setq ss2 (ssget "X" (list (cons 0 "CIRCLE") (cons 40 rad) (cons 8 layerType)))) (if ss2 (progn (setq j 0) (while (< j (sslength ss2)) (setq clear (ssadd (ssname ss2 j) clear)) (setq j (1+ j)))))) (T (setq len (vla-get-length (vlax-ename->vla-object eName))) ;; Tüm çizimde aynı uzunluğa ve layer'a sahip ögeleri seç (setq ss2 (ssget "X" (list (cons 0 (cdr (assoc 0 ent))) (cons 8 layerType)))) (if ss2 (progn (setq j 0) (while (< j (sslength ss2)) (setq ent2 (entget (ssname ss2 j))) (if (and ent2 (= len (vla-get-length (vlax-ename->vla-object (ssname ss2 j))))) (setq clear (ssadd (ssname ss2 j) clear))) (setq j (1+ j)))))))) (princ "\nHatalı varlık algılandı.")) (setq i (1+ i))) ;; Seçilen ögeleri vurgula (sssetfirst nil clear) (princ) ) Edited July 28, 2024 by SLW210 Added Code Tags!! Quote
SLW210 Posted July 28, 2024 Posted July 28, 2024 Please use Code Tags in the future. (<> in the editor toolbar) 1 Quote
SLW210 Posted July 28, 2024 Posted July 28, 2024 Please see https://lee-mac.com/errormessages.html Quote bad argument type: lentityp <value> A function requiring an entity argument has been passed an argument of incorrect data type with the value noted in the error message. Usually a result of passing the entget function a null entity argument. 1 Quote
BIGAL Posted July 29, 2024 Posted July 29, 2024 1st answer is that ChatGP is very unreliable so many times code is totally rewritten. 2nd "selects entities of a specified length from the entire drawing" length is not a searchable property must get object 1st then can get Length property. You dont say what you want to do with answer so just made a list of lengths. (defun c:wow ( / ss len) (setq ent (entsel "\nPick a object for layer ")) (setq lay (cdr (assoc 8 (entget (car ent))))) (setq ss (ssget (list (cons 0 "LWPOLYLINE,line,circle,Arc")(cons 8 Lay)))) (if (= ss nil) (progn (alert "You have not selected any correct objects \nWill now exit")(exit)) ) (setq lst '()) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (setq objname (vlax-get obj 'objectname)) (cond ((= objname "AcDbArc")(setq len (vlax-get obj 'Arclength))) ((= objname "AcDbLine")(setq len (vlax-get obj 'length))) ((= objname "AcDbCircle")(setq len (vlax-get obj 'Circumference))) ((= objname "AcDbPolyline")(setq len (vlax-get obj 'length))) ) (setq lst (cons len lst)) ) (princ) ) 1 Quote
