ReMark Posted October 13, 2011 Posted October 13, 2011 oasis: Did you change your path to acad.pat and forget to inform AutoCAD? Quote
mckymntl1 Posted May 20, 2014 Posted May 20, 2014 when i try to use these hatches, it looks like the lines are all broken, how do i fix that?....kind of a while since this subject has been breached but still would like to know Quote
hugha Posted May 20, 2014 Posted May 20, 2014 Try the control on the hatching dialog to move the hatch origin close to where you are hatching. If that doesn't work please provide a more detailed example. Quote
Dana W Posted May 20, 2014 Posted May 20, 2014 when i try to use these hatches, it looks like the lines are all broken, how do i fix that?....kind of a while since this subject has been breached but still would like to knowSome of them do have non-continuous lines. Otherwise, are you by chance placing them on a layer that has a HIDDEN line property? Quote
mckymntl1 Posted May 20, 2014 Posted May 20, 2014 Try the control on the hatching dialog to move the hatch origin close to where you are hatching. If that doesn't work please provide a more detailed example. wow that worked. its like i just needed to change the origin like u said and it rebooted all the hatches so they all work now. thank my friend Quote
ReMark Posted May 20, 2014 Posted May 20, 2014 when i try to use these hatches, it looks like the lines are all broken, how do i fix that?....kind of a while since this subject has been breached but still would like to know Scaling issue or you inadvertently put the hatch on a layer that has a dashed or hidden linetype assigned. Quote
hugha Posted May 20, 2014 Posted May 20, 2014 wow that worked. its like i just needed to change the origin like u said and it rebooted all the hatches so they all work now. thank my friend No worries. Quote
