Hi all (AutoCad 2007)
I am trying to run VBA code from the command line by using just CTAG as the name. In searching the net seems like I need a small lisp function.
I dug up this code off of the net and put it in the acad2007.lsp file
Defun C:CTAG()
(vl-vbarun "C:\\TestProject.dvb!Blocks.InsertBlockS")
While it sort of works... It runs my program on startup but I don't want that, I just want it to run when I use the command line and type CTAG. But when I do this it says it cannot find the command. hhhmmmm....
I think I am close but what am I doing wrong?
Thanks all!
I know very little about VBA, but could it be that you missed the first parenthesis?
[b][color=Red]([/color][/b]Defun C:CTAG()
thanks!!! Yep, as simple as a missing parenthesis!!!!
that's a relief! I also go over w/ those dilemmas...
careless;P
I'm assuming from a missed parenthesis mistake that you don't use the Visual LISP Editor in ACAD to create your LISP files - if not, I would definitely recommend it, just type VLIDE at the command line. Debugging options there as well.
