hetauma Posted March 24, 2009 Share Posted March 24, 2009 ok let's say that I have one surface (1) and then I make another surface (2) within the first one. I make the second one a component because it's something I want to use quite few times. While editing the component (2) just a surface for now, I try to push it inside the surface (1) but that can't be done. i.e. changing the geometry of the component can't affect the geometry of the surface that it is attached to. Any ideas why? Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted March 25, 2009 Share Posted March 25, 2009 You can push surface 2 into surface 1 before you make it into a componant then select it and make componant and tick the 'CUT OPENING' box then when you copy your componant it will always cut away surface 1.! Hope this helps let me know if it isn't clear! Quote Link to comment Share on other sites More sharing options...
hetauma Posted March 25, 2009 Author Share Posted March 25, 2009 You can push surface 2 into surface 1 before you make it into a componant then select it and make componant and tick the 'CUT OPENING' box then when you copy your componant it will always cut away surface 1.!Hope this helps let me know if it isn't clear! Got it thanx very much Quote Link to comment Share on other sites More sharing options...
