search texts in several dwg simultaneously...
I would like to know if this is possible and how?
I appreciate any comments
Use ODBX, open your dwgs one by one, save results in a list and close searched dgws.
Store the results in al list, note name and path.
No need for a third-party-tool.
Expand
I reckon most LISPs and automation could be seen as a third party tool....
Isn't Object DBX a "third party tool"?
Plus, you actually didn't detail how to do this method.
Yes it is possible as SLW210 but also via LISPs
For LISP you'll want to use a batch LISP routine - something like ScriptPro or Lee Macs Script writer to assess each drawing. These will run a LISP to search text strings, so now all you need is that....
If you are using a script you want minimum user interface, anything without a dialogue box, I think this is the basis of what I use:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/find-and-replace-text/td-p/5649883
(I refer to it in my LISP find and replace). Modified to record what it finds into a text file.
Is it normal text you are searching for? If the text will be for example in a title block, again Lee Mac has a solution with his MacAtt tools, https://lee-mac.com/macatt.html
- ODBX is provived by autodesk
- search this forum, there are plenty of examples
Expand
Edited by wkplan
what I want is not to replace texts.
I am looking to open several dwg.
then search for a text string in the open dwg.
I would like the tool to tell me in which dwg the text I am looking for is in.
try to install  DwgSearch | AutoCAD | Autodesk App Store
I use the 2013 version Autocad :(
and I couldn't install
an apology, I already saw that what I need is done
Batch Find & Replace Text by Master LEE
 thanks
